Venom Intake Manifold?
IMO, you'd be better off boring out your stock one or an h23 IM. Doing that would probably give you the same results you'd see from that venom but for alot less. You might even see more of a result with a bored h23/A6 then you would that single runner venom. that's just IMO thoughHorsepower sells cars, torque wins races.
Ive seen them in a Civics engine bay. I guess it works not sure wouldnt know. You can test it and let us know!!!
those benefit a boosted motor more than a N/A motor. other than looking cool is all you'd get from it.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
I dont know much about that one but the skunk 2 intake manifold mades a big difference on the h22.Oil leak?What oil leak? That's just sweat from all that horsepower!
Applied knowledge is power!
NITROUS FOR YOUR BODY
BIRTHDAYS ARE JUST AROUND THE CORNER
registration is free
Originally posted by koolkoreankedI dont know much about that one but the skunk 2 intake manifold mades a big difference on the h22.
Originally posted by cp[mike]where have you read that? i heard they arent all they were supposed to be, 2point6 found he lost power with itRetired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
yes 2point6 has a totally different setup. he even stated that for his app, the euro manifold gave him better gains and that with more tuning he might have been able to gain. so it wasn't worth the time and money for him. so it was better for him to switch back to the euro. for some, the skunk will make a big difference. its a car to car basis. with just bolt ons i am sure it works well. it has longer runners which i think 2point6 said could have been his loss. i can't understand what the skunk2 requires the install that it does though. i figure all the components that go on the manifold should have been retained just as the stock unit. i have even seen some people that say it don't fit and others that say it fits fine. if i find a euro some where already done up for the jdm/usdm h22, i'd go that route instead of skunk2 though. In conjunction with 2point6 i have read both pros and cons on them. I hear that the h22 skunk2 was a disappointment vs the other platform manifolds.91 Ex CB9
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
As far as bolting it on the car you need to get a oil filter relocation kit if I remember correctly. That could be why some people say it fits and others say it doesn't.Oil leak?What oil leak? That's just sweat from all that horsepower!
Originally posted by EXkidd91IMO, you'd be better off boring out your stock one or an h23 IM. Doing that would probably give you the same results you'd see from that venom but for alot less. You might even see more of a result with a bored h23/A6 then you would that single runner venom. that's just IMO though
