Go Back   CB7Tuner Forums > 4th Gen-eral > Other Automotive > Other Automotive Members Rides
Old 09-14-2007, 11:09 PM   #1
blackice
blackice is cool... so far.
blackice : 1998 Nissan 240SX SE
My car was originally automatic, has no abs, but has a sunroof and is 5 lug. When I bought it, it was already swapped to 5 speed with the VIS Omega front bumper. The stock KA24de ended up blowing a headgasket on me after a series of water pump issues.
Powertrain:
Engine:
1995 Series 1 S14 SR20DET
A/C removed
Cruise Control removed
Drivetrain:
Stock 5 Speed S14 SR20det transmission matching engine
Steel braided clutch line
Cusco Shifter Collar
GKTech SR20 5 Speed Shifter Spring Kit
OS Giken Super Single Clutch - Aluminum Housing
Nismo Clutch Pivot Ball Stud
Skyline R33 GTS-T 3.63 differential (shimmed) and pumpkin (S14 diff cover)
Intake and Fuel (Suck):
Nissan 300ZX MAF (1990+) 75mm
Apexi Super Intake Suction Kit for Z32 MAF
Greddy Aluminum Hot Pipe for S14 SR20DET
Greddy VSPL 24V Frount Mount Intercooler for S14
Greddy Type RZ Limited Edition Blow Off Valve
555cc Side Feed Injectors
Bosch 040 In-Tank Fuel Pump
Adjustable Fuel Pressure Regulator
Internals (Squish):
ARP Head Stud Kit
Cosworth Metal Head Gasket Stock Specs (87mm x 1.1mm thick)
Ignition and Turbo(Bang):
Stock S14 Single Ball Bearing T28 Turbo
DIF Bottom Mount Turbo Coolant and Oil Lines Kit
HKS Wastegate Actuator Kit for S14
HKS Type-S Oil Cooler Kit - S14 SR20DET
codyace 125 Amp Quest Alternator upgrade kit
Exhaust(Blow):
Aftermarket O2 Housing/Turbo Elbow
Aftermarket 3” downpipe
Blitz Nur Spec R Exhaust
Cooling
Blitz Silicone Upper Radiator Hose and Sensor Bung - S14 SR20DET
Carisma S14 KA24DE to SR20DET swap heater hoses
Nismo 1.3bar Radiator Cap
Stock clutch fan
Stock radiator
Chase Bays Power Steering Upgrade Kit for Nissan S13 and S14 240sx - Stainless Steel Lines, Reservoir, and Cooler
Electronics:
Apexi Power FC 1994-1996 Nissan Silvia S14 Series 1- L-Jetro (MAF) ECU
Apexi Power FC Commander
FC Datalogit
Blitz SBC i-D Spec R Electronic Boost Controller - Jet Silver
PLX DM-6 Gauge and SM-AFR Gen 4 Wideband O2 Sensor Kit
Greddy V2 52mm Black Electronic Boost Gauge
Greddy V2 52mm Black Electronic Oil Pressure Gauge
Greddy/Trust 60mm White Electronic Water Temperature Gauge
Die-Hard Platinum gel cell battery
Custom battery box relocation to trunk - 0 gauge wire
Rockford Fosgate 3 way splitter for engine bay positive
Rockford Fosgate battery ground
Rockford Fosgate Maxi fuse holder and 100 amp fuse for battery relocation kit
Suspension/Control:
HKS Hipermax IV SP Coilovers - S14/S15 240sx
Front Enkei RPF1 9.0” +35
Rear Enkei RPF1 9.5” +15
Nitto Invo 255/40/R18
Nitto Invo 235/40/18
Muteki SR48 Extended Open Ended Lug Nuts
Nismo 60mm Extended Lug Studs
Front:
Nismo Power Brace S14/S15
SPL Parts - Pro V2 Front Pillow Ball Tension Rods S14
SPL Parts - Pro V5 Outer Tie Rod Ends
Tein Tie Rod for Infiniti G35, Nissan 350z with spacers
Energy Suspension Front Steering Rack Bushing Set for S14 240sx
Energy Suspension Sway Bar Bushing Bracket for S14 240sx
Nismo Motor Mounts
Nismo Transmission Mount
Rear:
SPL Parts - Prov V3 Rear Toe Arms S14
SPL Parts - Titanium Rear Traction Rods S13, S14, Z32
SPL Parts - Titanium Rear Upper Control Camber Arms S13, S14, Z32
SPL Parts - Pro V2 Solid Subframe Bushings Kit S13 and S14
SPL Parts - Pro Solid Differential Bushings S14 and Z32
SPL Parts - Eccentric Lockout Kit S14
Brakes:
Z32 17/16 Brake Master Cylinder
Front:
Brembo 300ZX Blanks
Stoptech Performance Pads for 300ZX
30mm Aluminum 300ZX TT Caliper
Circuit Sports Front Brake Line for Z32 Brake Conversion
Rear:
Brembo 300ZX Blanks
Circuit Sports Rear Brake Line for Z32 Brake Conversion
Non-Turbo Z32 e-brake/splash shield setup
Non-Turbo Z32 hub/bearing
R33 Skyline GT-S E-Brake Cables
Exterior:
Carbon fiber oem style hood
Nissan 200sx S14a front bumper
Nissan 200sx S14a turn signals
Mculloch HID kit 4300k
Nokya 2500k High Beam bulbs
Interior:
Nardi Torino Personal steering wheel
Works Bell hub
JDM 200SX Floor Mats
Future Plans:
NRG short hub, quick release and lock for steering wheel
740cc Nismo Side-Feed Injectors
Garrett GTX2867R Turbo
Tial MV-R 44mm External Wastegate
Doc Race Top Mount Manifold
Tomei PonCam
Tomei Rocker Arm Stoppers
Kouki K’s rear spoiler
S14 OEM Information:
Production: 2178 S14a's were exported to the USA in 1998
Body style 2-door coupe
Engine 2.0 L SR20DET (1998 cc)
Max Power 217 hp
Max Torque 203 lb·ft
Wheelbase 2525 mm (99.4 in)
Length 4498 mm (177.0 in)
Width 1727 mm (68.0 in)
Height 1288 mm (50.7 in)
Curb weight 1220kg (2689 lb)
Seating Capacity 4
The stock S14 SR20DET has a thrust bearing t28 pushing 11lbs of boost.
Retired 1990 Accord LX Coupe
Project 240SX
Originally Posted by chillin943
anyone kno if i can just make a hot wire for v-tec off the horn??
Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, rosko
blackice is offline   Reply With Quote
Old 09-14-2007, 11:12 PM   #2
lil_dcb7
lil_dcb7 is cool... so far.
Send a message via AIM to lil_dcb7 Send a message via MSN to lil_dcb7
What the hell is it with 240's?
I swear to god
Claire - '92 Mercedes-Benz 500E - AMG&Bilstein Treatment - The Wolf in Sheep's clothing.
Alice - '97 BMW 540i6 - Dinan Tuned. - Low Profile Weekend Warrior.
Felicia - '11 Ford Fusion - Luxury Package - Daily.. daily.. ugh.
Originally Posted by JoshM View Post
Okay to do: "I'm sorry I broke your mailbox, here's $100.
NOT okay to do: "I'm sorry I fucked your sister, here's $100.
lil_dcb7 is offline   Reply With Quote
Old 09-14-2007, 11:16 PM   #3
PRIMOCB7
PRIMOCB7 is cool... so far.
Send a message via AIM to PRIMOCB7
one of my favorite imports of all time. i always wanted one of these if i didn't have the cb7 back then. plenty of potential for sure. keep it clean
5.6L V8 32V DOHC
JDM HERITAGE - US BUILT
PRIMOCB7 is offline   Reply With Quote
Old 09-14-2007, 11:23 PM   #4
blackice
lol yeah i'm gonna miss my cb. i have actually been through two cb's now. the biggest thing i'm gonna miss is my h22. the ka24de just doesn't pull like that thing did. no worries about keeping it clean. i'm going to try to get rid of the kit bumper and go back to stock...or possibly a silvia bumper
Project 240SX
Old 09-14-2007, 11:26 PM   #5
HA91
HA91 is cool... so far.
Send a message via AIM to HA91
Looks good i like these models alot
UPDATED NEW PICS!!!
HA91 is offline   Reply With Quote
Old 09-14-2007, 11:43 PM   #6
SMseagren83
Accord of the Month: October 2007
SMseagren83 is cool... so far.
Send a message via AIM to SMseagren83 Send a message via MSN to SMseagren83
this car is gonna be off the hook with a lil time & help.
his old CB will live on through mine.....sort of.
dude MINI MEET tomorrow..after i wash my car. set it up!
F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
SMseagren83 is offline   Reply With Quote
Old 09-14-2007, 11:50 PM   #7
almostJDM
almostJDM is cool... so far.
Send a message via AIM to almostJDM Send a message via MSN to almostJDM Send a message via Yahoo to almostJDM
screw the rb25det go rb26dett
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Not so DD 2013 Subaru Impreza WRX STI
Boosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
almostJDM is offline   Reply With Quote
Old 09-14-2007, 11:52 PM   #8
NAiL05
CB7Tuner Member
Location: Dallas, Waco, And now SIUC for school I'm going worldwide bitches!!!
NAiL05 seems to have made some friends!
Yea! rb26 go big or go home! haha.
The New-ish Ride
My old Ride
Hear my Vtak!!!
MK3 Member #3
I piss off people for fun.
IA 08 Sunburn Victim #1
NAiL05 is offline   Reply With Quote
Old 09-14-2007, 11:54 PM   #9
SMseagren83
i think price diff is a factor. there is PLENTY of potential in the RB25. dont think he is trying to turn it into a drift/drag machine. i do believe its his DD/project.
Old 09-14-2007, 11:55 PM   #10
accordaffair
accordaffair is cool... so far.
Send a message via ICQ to accordaffair Send a message via AIM to accordaffair
Theres a gold one of those in my town, I love when I can see that grille/front fascia in my rear view mirror and the only thing I can hear is the turbo spooling....
I raced him once against a WS6 firebird, haha, well they were racing, I was just fucking around, but I wanted to see how fast they could go, I think he beat the firebird by a narrow margin, but shit they were fast...
accordaffair is offline   Reply With Quote
Old 09-15-2007, 12:36 AM   #11
Rosko
Rosko is cool... so far.
Send a message via AIM to Rosko
verrr nice!
www.roskoracing.com << Euro-R manifolds/adapters and H22 parts
>>check out my H23vtec build thread...
http://www.honda-tech.com/zerothread?id=2030543
Rosko is offline   Reply With Quote
Old 09-15-2007, 04:07 AM   #12
kouzie
kouzie is cool... so far.
wow.....super sexy.........
kouzie is offline   Reply With Quote
Old 09-15-2007, 04:54 AM   #13
Dv8
Dv8 is cool... so far.
Sweet.
Now put a 1JZ in it. Fuck RB.
I swear to god
And who cares
Dv8 is offline   Reply With Quote
Old 09-15-2007, 08:03 AM   #14
Fake Thug
Fake Thug is cool... so far.
Very nice Kouki. You know if that KA isn't too high on mileage, its be cheaper to just build/boost it instead. IF u change your mind though and swap engines consider an LSX drivetrain. More power out the box than all other potential swaps.
Fake Thug is offline   Reply With Quote
Old 09-15-2007, 09:09 AM   #15
accordtypeR
Accord of the Month: August 2008
accordtypeR is cool... so far.
Send a message via MSN to accordtypeR Send a message via Yahoo to accordtypeR
Dang buddy im loving the car...clean, simple, and MEAN at the same time.
My Old Baby
SOLD TO
accordtypeR is offline   Reply With Quote
Old 09-15-2007, 11:43 AM   #16
GREENCB3
GREENCB3 is cool... so far.
Nice pick up
Project EP hatch on the way
GREENCB3 is offline   Reply With Quote
Old 09-15-2007, 11:52 AM   #17
lo-specials
lo-specials is cool... so far.
Send a message via MSN to lo-specials
Just get the rest of the bumper kit
nice ride bro
Your car is faster, I'm the better driver
Greetz Erwin
My last ride
Shakes and Fidget - The Game
lo-specials is offline   Reply With Quote
Old 09-15-2007, 02:13 PM   #18
DTaccords85
DTaccords85 is cool... so far.
I always loved those car but with the taillights off of a 90 91 240 it looks sick.
DTaccords85 is offline   Reply With Quote
Old 09-15-2007, 02:37 PM   #19
phatdoughnut
phatdoughnut is very helpful phatdoughnut is very helpful phatdoughnut is very helpful
Send a message via AIM to phatdoughnut
my friend had one of those with those ADR Version2s that snailing had on his accord, huge lip on th eback. It looked so good.
phatdoughnut is offline   Reply With Quote
Old 09-16-2007, 04:18 PM   #20
SMseagren83
Updated photos...
Not a REAL photoshoot..just a couple quick snaps! his car needs to be completely detailed before i spend time doing a real photoshoot. hhaha
better get on that cory! these should be better than the ones u got now... lol or not
