Engine Performance:
P28 ecu with added iabs
Crome basemap
JDM 1994 H22A
JDM M2A4 Transmission (non-lsd)
JDM OEM header and downpipe
custom 2.5" crush bent exhaust
Magnaflow 2.5" catalytic converter
26" 2.5" resonator
OBX Twin-loop muffler
Unorthodox Racing Ultra S underdrive pulley
Gates K060345 Belt
Iceman BB4 cold air intake
K&N cone filter
custom egr blockoff plate
Moroso oil pan stud kit
M-Force magnetic tranny and oil pan kit
MSD 8.5mm Super Conductor spark plug wires
NGK Iridium IX spark plugs
billet spark plug cover
Stage 2 Centerforce clutch
deleted A/C, P/S, C/C
Euro-R intake manifold
RoskoRacing obd2-obd1 adapter kit with blockoff plates
custom throttle cable bracket
S2000 throttle body
Hondata intake manifold gasket
AEM Hi-Flow fuel rail
Not installed:
AEM intake bypass valve
Cusco 9mm oil catch can
Exterior:
JDM CB6 two piece headlights
McCulloch 5300k H4 HID kit
Nokya 2500k H1 bulbs
Amber LED 194 corner bulbs
92-93 front bumper
92-93 trunk lid swap
deleted H and LX badges
Cusco hood pin kit
red/clear tail lights
Not installed:
1991 Acura Legend Coupe Lip
JDM CB3 rubber fog moldings
EDM CB3 smoked sidemarkers
EDM Rover clear sidemarkers
JDM CB3 amber sidemarkers
JDM CB3 intersection lights
EDM CL1 rear fog
JDM CB3 mud flaps
USDM CB7 flushmount spoiler
DA9 Integra GS spoiler
EDM CD5 rear sidemarkers
JDM R33 Skyline sport grill
JDM G-Square eyelids
JDM CB3 clear bumper signals with amber inserts
EDM CB3 clear sidemarkers
JDM CB3 Foglights
PIAA H120 85W H3 bulbs
new 92-93 bumper
Interior/Electronics:
92-93 interior swap to gray (originally maroon)
OEM gray floor mats
92-93 manual seat belt conversion (brackets fabbed and fitted by maroonaccord2.2)
custom short shifter bracket and bucket flip (courtesy of BustedLX)
Viper 5000 2-way paging alarm
custom fuel cutoff
MOMO match anthracite pedal set
genuine carbon fiber custom shift boot
JDM CB3 fog light switch
EP Racing SB-S shift knob
BB6 Prelude gauge cluster
Not installed:
custom cold cathode trunk light
AEM UEGO 6-1 Wideband
HULOG datalogging cable
Autometer Sport Comp 5" Tach
Autometer Pro Shift-Lite
carbon fiber e-brake handle
EDM rear fog light switch
Suspension/Control:
CD5 EX rear disc brake swap
Russell stainless steel brake lines
Brembo blank rear rotors
Hawk HPS rear pads
Energy Suspension Master bushing kit
Ingalls front concentric camber kit
Energy Suspension front motor mount insert
Suspension Techniques front and rear sway bars
KSport Pro Kontrol Full Coilover kit
16" Enkei Racing S wheels +32 offset, front 16x7, rear 16x8
BFGoodrich g-Force tires 205/50/16
Not installed:
Collective Racing traction bar (Courtesy of 2point6) *Snapped*
Generic front strut bar
15" 92-93 EX wheels
15" MOMO M1's
Nitto NeoGen tires 205/50/15
4040 DA9 Integra brake proportioning valve
Prothane rear motor mount insert
Prothane rear bushing kit
Misc OEM replaced parts/fluids:
axles, 2x drivers side
iacv
fitv
front rotors
front calipers
front dogbone engine mount
o2 sensor
dot4 brake fluid
window channel guides and pin kit
Honda Redline MTF fluid
Quaker State High RPM Full Synthetic 10w-30 oil
thermostat
top radiator hose
heater blower motor
Future Plans:
Swap everything to 93 ex coupe shell
M2B4 Transmission
rear strut bar
header
cams
pic from a few months ago of the engine bay
Currently I'm waiting on a dyno tuned map from Dave Leed that Jose (d112crzy) picked up for me. I'm gonna street tune that to get the afr to spec then probably take it to the dyno to get the timing correct.
