Check engine light frustration
    After cleaning the EGR runners, changing the oil, changing manual tranny oil, fuel filter, cleaning IACV, cleaning thottle body, new o2 sensor, plugs, wires, cap, rotors, ignition coil, new air filter, new exhaust, radiator flush, new thermostat and still can not get rid of the dreaded "check engine light". After I did all of this I even reset the computer, and it still comes on after driving for like 2 minutes. The actual question I had was could my broken speed sensor set off my CEL light since my speedometer and odometer dont work? If not, any suggestions on what it might be? Thanks alot...
    90 lx
    dawg.. dont worry bout it.. it's saying to check ur engine cuz that bitch is cleannnn lol
    DEFJAM
    MY RIDE ON CB7 DEFJAM on 93
      THATS WHY IT CAME ON!!!!! ....i hope u didnt do all that because of the Check Engine Light.
      Project M3 - http://www.cb7tuner.com/vbb/showthread.php?t=157903
      -(B-Pillar Bar Originator)-
        thanks
        so the speed sensor is the cause of it? Good to know.....and by the way I just did all that cause the car was a POS...lol....
          Note to self: Pull engine code before I waste all this time and money on something that doesn't even relate to the particular problem.
          This is a prime example why we stress to our customers at work about not messing with their vehicles if they have no clue wtf they are doing...
          Pull the code, fix whats wrong. Just cause the speedo isn't working doesn't mean thats the only code its throwing...
            i dont pay mind to the engine light, i just make sure the important stuff is taken care off. I had the check engine light on my old cb7 and now i have it on my new one!
              worst_advice_ever
              it takes 2 seconds to pull the CEL code. the car is telling you exactly whats wrong with it... dont take it lightly
                Originally posted by cp[mike]
                worst_advice_ever
                2 seconds
                Really?? How do i go about this then bro??? Is there a link you can throw to me here???
                *Needs*
                -New shocks
                -Struts
                -Drop
                -Cleaning
                -New Tires/Wheels
                -New Window Tint
                -Alot more lovin'
                  Originally posted by Djmoua
                  2 seconds
                  Theres a little jumper plug on the passenger side by the glove box, you take a piece of plain wire and strip the insulation on both ends then put both ends of the wire into the jumper...
                  Once you've done that turn your key on but don't start thr car and the CEL will start to blink, count the blinks pay attention to the blinks as well because some are short blinks and some are longer.
                  Count them and let me know what you got, i just so happen to own and sell automotive diagnostic and repair software (Mitchell1)
                  CiRcuS kiNgZ
                    yes it doesnt take long. One long = 10 and the short = 1. Check engine lights are there for a reason not to be ignored. Do not listen to anyone that says to ignore check engine light. Its there for a reason.
                      x2....other things could be wrong too besides the vss..always double check!
                        Thanks guys....never bothered to pull the code cause I never knew how to in this car(only had it 2 months or so). I've done it in my truck but it had one of those nice little plug in things under the drivers side dash. So just take a paper clip, unfold it, stick an end in each wire, turn the key and watch the blinks? Sounds simple enough, Ill give it a try this weekend since high school takes up all my f*cking time
                          Or you could use a paperclip..but heres the question...on my man's ...I think umm..his first tan Cb7 and his tan Auto Ex he had..CEL light was on...and there was NO JUMPER PLUG ...me and him both looked for it...took off the passenger side kick panel..took a flashlight..and no jumper plug
                          both were 90 cb7s...and also..on mine..NO JUMPER..I wonder if honda didn't include jumper plugs until 91-93??
                          all I know is..he was PISSED...that he couldn't figure out whats going on with those cb7s and mine as well!
                          we are both puzzled!
                            I have a 90 EX-R, it has a jumper plug, even though it doesn't seem to work as my light is constantly on and i get no code, but then again you might be right with this and i'm shorting out a plug I shouldn't be, lol (HMM maybe i'm causing this stupid CEL to come on)
                            the joys of digging into an old car, its like christmas every time you try to fix something. "woohoo!! more rust and broken parts! sweet!!!"
                              they all have it, if you have never used it sometimes it is taped to the wire loom up behind the right side of the glove box, it should be a small blue plug
                              Retired 1990 Accord LX Coupe
                              Project 240SX
