Hey everyone as you know your h22 type s candidate needs your info on the stock h22 jdm tranmission. For starters im getting my synchros changed might I add I have a bit of a grind in second and 3rd when i runt he car hard. Ive narrowed it down to my tranmission synchros. Now the solution I plan to take my transmission out and take it to a local whos good at doing tranmission fixes. An ASE certified mechanic well doing transmission is not my fortee so ill be brief.
I need to know the following now the jdm h22 gears are shorter than the usdm gears but about by how much. Ive spoken to gearspeed they said that the gears on the jdm is shorter than the usdm. I wonder if it was worth it waiting for the gears to arrive from them aswell as ordering the carbon coated synchros from them or should i go with the usdm gears that way theres more availability. Because either way its one of the other. And are they interchangeable.
Last but not least just how short are they in difference in the gearing and will it somehow hinder my times? Can anyone please post the difference in the gearing the jdm tranny vs the usdm tranny gearing? If you can that would be greatly appreciated thankyou.
