g23 belt question
    g23 belt question
    f23 block - h23 head in a non cb7; 6th gen
    my friend has it in the shop now and has tried several different timing belts with no avail.
    i know tht this aint a cb7, but i believe adam did this exact swap and had this working
    we tried B20 (from old prelude), H22, H23. or best bet was a gsr belt, but its too wide and rubs.
    on the dohc f22's, a gsr belt works fine. so there is some diffence in f22 and f23 bottom ends
    other info: stock h23 cam gears; h23 lower cam gear
    any help or any other belts tht we could try would be helpful
    174.92 BHP / 171.45 WTQ
    might want to use a string to measure what size of belt you need along with width as far as ribs go. check out gates belts, they have a good catalog of different belts
    Retired 1990 Accord LX Coupe
    Project 240SX
      mine [gsr belt] was too wide so the gears naturally just trimmed it off when it was running so expect black powder all over the place.
