what ecu is the best for a modified h22a in a cb7? ive talked to and read that the p13 isnt that great of an ecu to modify...i also heard that the p28 is the best ecu to use because it can be easily modified...but what about the p72? what do you guys run?
best ecu for h22
They do have an obd1 p72. Both ECUs work well but I prefer the P28.
The P28 is good. I'mr unning one with a Hondata S300 and it's great, but it doesn't support the knock sensor (not a big deal) or the IABs (which I would prefer it did), but the P72 does support the IABs and you can put a chip in it or a Hondata if you have the $600 or so to spend on it. I like the "tune on the fly" ability of the Hondata S300...Originally posted by Junior SmurffNevermind guys, google search works wonders!
I don't have road rage, my car just goes faster than yours!
Accords are for winners. And Grandmothers. But mostly winners.
I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
some info on chipping ecu's.
http://cb7tuner.com/vbb/showthread.php?t=56836
it doesnt matter which ecu you get, as long as its chipped with the things you need.(it needs to be one of those ecu's listed tho)
a chipped p06 with vtec and iabs works just as well as a p72, and its also much cheaper unless you get a p72 or p28 for cheap.
but its not the ecu itself that makes the difference, its the map and how its tuned thats most important.
most common option is the p28. its easier to get. although when i do my swap within the next month i will be running a jdm p72 w/s200. the p72 is harder and more espensive but closer to the p13 than the p28.91 Ex CB9
JDM h22 auto swap, now w/H23 5spd conversion, short ram intake w/K&N filter, DC ceramic header, 2.25" custom catback exhaust, AMR Engineering coilovers, 205/50/16's Enkei RS5's, front slotted rotors, Xenon body kit.
W.I.P.
p72 ecu on Hondata
To Come
Weight Reductions
R33 or R34 front end
Originally posted by d112crzyp06 is easier to get. but it all depends on the junkyards around you.
and again, it doesnt matter what ecu it is or how "close" it is, as it will be chipped and tuned(hopefully)
My p28 supports iabs just fine thank you
check out pgmfi.orgRetired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
Originally posted by jtek24Im not sure exactly what P# the ECU is, but jspech22acclude has an teggyGSR ECU, and that thing flies with no limiters on it. Unchipped and accelerates like a bat outta hell!
Originally posted by NAiL05How is that possible unchipped. Yea it will run it but the gsr map will make the h22a run like shit. YOu have to chip it either way. And its a p72.Retired 1990 Accord LX Coupe
Project 240SX
