IAB Help!!!
    IAB Help!!!
    Yes I know there is a lot of threads on here about this stuff but I'm hoping you guys can help
    I'm swapping in the h22 and I need the IAB vacuum tank and the solonoid valve and when I called honda they didn't know what it was. They were saying something about it being my IAC???
    But I'm hoping someone has some advice on what to do can I run the car without or just any advice would help I'm stuck for what to do next and I know you guys will help me out.
    I look...You look
    I rev...You rev
    I win...You lose
    vspooled
    http://www.hondaautomotiveparts.com/...NIFOLD+%282%29
      look this is what you do, ditch that solenoid and all that shit. just plug it from the by-pass valve to a open vacuum source in the back of the manifold and your golden
        this method DOES NOT work like its supposed to....as soon as you hit WOT the IABs will open.....only way to corretly have the IABs closed til 4800rpm is to have that solenoid!
        F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
        Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
        Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
          x2, From what I can tell on my h22 (iabs hooked directly to the intake manifold) the iabs wont open UNLESS u go wot. I'm also trying to get an iab solenoid and vac box, junkyard here I come.
          Retired 1990 Accord LX Coupe
          Project 240SX
            or you can just not hook up the vacuum line off the diaphram and the secondaries will remain open all the time. you will loose low end torque but i'd rather lose that than high end power. gas mileage will suffer a bit too.
            you can also use an IAB box from other motors like your f22a6 (EX, SE accord motors), integra GSR, etc. good luck!
            1cor10:31
            - 92 LX coupe
            - 96 EX wagon (sold)
              i got the gsr iab box if you want 25.00 + shipping. pm me-
              http://www.myspace.com/ilovevee
                They will open anytime the vacuum in the IM drops low enough to no longer keep them closed. Abrupt throttle movement will do this also.
                Rev your engine and watch them open.
                  Whats the problem? my car is fast with them being hooked up directly to the intake manifold? and i get great gas mileage too.
                    >off topic< I didnt want to start an entire thread for this.
                    Is it possible to retain IAB function with the P28 ecu? Or would the hondata system have a provision to make it work properly? And at the very least could a RPM switch be used to control them, augmenting the P28?
                      Phearable.net said they could not add IAB function to my P28, but only because they test all their ecus in car and they didn't have a test vehicle for IAB. I'm sure it can be done
                      I heard unplugged from vac is better if no box.
                      I also have a friend who got shorter hardware for the manifold and removed his butterfly plate completely with no noticed drawbacks.
                      I'm going P28 + Skunk2 manifold to benefit from no IAB control
                      I have vac boxes/solenoids from H22s, H23s and F22A6s, let me know if you still need one.
                      PM me and get it done right!
                        I have my iabs running right finally woot and on a chipped p28 too.
                        Project 240SX
                          to wire the iabs into a p28 all you gota do is solder a few wires and resistors. well, its a lot easier on an auto p28 because it has most of the stuff needed for iabs, the manual ones are a bit more complicated.
