can our cb7s use low offset (like +15) wheels and get the big 2.5" + lip? I currently have 18x7.5 with a 2" lip and there is no way anythin wider will fit without rubbin, and if the offset is changed by -5 ill rub the inside in the back. So how do all these civis and integras below do it:
Low offset, big lip, wheels on a cb7? (pix of other hondas inside)
1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
Member's Ride Page | Video of my CB7, Open Downpipe peeloutTags: None
some of these guys are fitting 17x9 and 18x8.5 into their EGs and DAs....I want a bigger lip but dont want the rims sticking out 2"s past the fenders1991 Accord LX Coupe - Boosted F22 - 5spd LSD - Shaved Bay - Work VSXX - Recaro SRD
Originally posted by hondaracer3315" or 18" wouldn't you have the same overall diameter anyways?
No my brother. Does a circle of 15" radius has the same diameter than a circle of 18" radius. Or is a 15" diameter circle the same as a 18" diameter circle I think you are probably thinking of the width of the wheel.
Na Lobi Bien Mua Café Mua Café Oyo Na Meli Elingi Ko Bima. J'aime les Madesu ya Mpembe que du Poulet!!!
depends what series of tire you are running too. right now i'm running +32 16x8s in back with a 205/50/16 tire. i bought the rims with used 225/50/16 tires on them and they rubbed fender around corners. i'm sure you have rolled your fenders already but running a stretched tire setup may help you a bit. running more negative camber also helps a lot as the tire will push up and towards the car as you corner. but i don't know how much clearance you have as far as the upper arm goes with the 18's...Retired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
OT: That red integra is fucking sick. holy science...Last edited by Accord R33; 06-12-2007, 07:17 PM.
Originally posted by hondaracer3315" or 18" wouldn't you have the same overall diameter anyways?Originally posted by seigneur_rayden
Sorry to confuse! I did say OVERALL. What I ment was, no matter what diameter wheel you chose, you typically select a tire size to match the OEM diameter. Therefore if you had 14" OEM wheels, then you might have a 185/70-14 tire. The overall diameter is 24.2". Therefore if you have an 18" tire you might select a 215/40-18 tire. Now your overall diameter is 24.77". Or you might chose a 215/35-18 tire which is 23.9". One is a little bigger and one is a little smaller, but as close as possible to OEM specs. Sorry if I sounded like a nooB.
Originally posted by hondaracer33Sorry to confuse! I did say OVERALL. What I ment was, no matter what diameter wheel you chose, you typically select a tire size to match the OEM diameter. Therefore if you had 14" OEM wheels, then you might have a 185/70-14 tire. The overall diameter is 24.2". Therefore if you have an 18" tire you might select a 215/40-18 tire. Now your overall diameter is 24.77". Or you might chose a 215/35-18 tire which is 23.9". One is a little bigger and one is a little smaller, but as close as possible to OEM specs. Sorry if I sounded like a nooB.
