Verification of p72
    Verification of p72
    Hello, I have an h22a swapped accord, and am planing on tuning.
    I am not stupid, hopefully, but I am cautious so I am verifying that this ecu will be chipable, able to run secondary's and be used with Neptune/ Neptune RTP.
    Again I am just making damn sure before I spend $200
    Thank You in advance.
    http://www.hmotorsonline.com/shop/wh...php?prodID=116
    201 Whp H22a with bolt ons, see the progress from stock f22a to now HERE
    You can use any other P06 and make it run IAB and vtec for way less than the stock P72. The one thing that the P72 does have is the Knock board but most people dont even hook up the stock knock sensor when tuned.
      Ok Then
      So a P06 can do it. What about a manual p28
        p28 will work it just doesnt have IAB built in on it. It also doesnt look for the EGR or KS. But you can make the p28 operate IAB just need to jump some pins.
          pick up an automatic p28, you can use the automatic controller portion of the board to run the iabs. just one jumper wire is all it takes...
          Retired 1990 Accord LX Coupe
          Project 240SX
          Originally posted by chillin943
          anyone kno if i can just make a hot wire for v-tec off the horn??
          Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, rosko
            Auto P06
            does the same thing work with auto P06 ?
              NO, you are going to have to add in Vtec and IAB if you use the P06. The parts are not that expensive anyway.
