94-97 rear disc conversion on a CB
    will 94-97 rear disc fit the 90-93?
    MRT: http://www.cb7tuner.com/vbb/showthread.php?t=95154
    yes, the only difference is part of the knuckle that the one of the main bolts goes through is longer on the 94-97. When I did my swap I measured the part on my drum brakes knuckle and used a chop saw to trim down the 94-97. Don't forget you will need the ebrake cables from the disc setup and the secondary fluid lines on the actual trailing arm.
    http://cb7tuner.com/vbb/showthread.php?t=10495
    Retired 1990 Accord LX Coupe
    Project 240SX
