So, my uncle's car has this problem.
When the car starts, the car has a pretty rough shake during idle. It's not something you'd feel from a bad motor mount. The car DOESN'T die out, but it has a shake especially after a full warm up. When accelerating, you feel the shake slightly, but it doesn't go away.
I looked at the plug wires and no oil. Could it be bad plugs (was changed before) that's causing this? Is this a case of misfiring? No CEL on the car though.
It doesn't really have this misfire pattern that you might feel, rather it just sounds like some belt, or something is causing the car's engine to shake.
Thanks.
Thanks.
