h22a4
    h22a4
    hi i am new and i am doing a h22a4 swap in a 91 lx. also doing a 5 speed swap. if in help would be nice thank u
    There is a swap sticky in the swaps section. It should help you out quite a bit. You cant post in there yet because of your post count but you can still see it. Its pretty informative.
      thanks
        Not knocking ya here bro but what kind of help are you looking for? Do you have a question or two? Or are you looking for someone to come give ya a hand? You have to be a little more detailed in what your asking for.
          i was just trying to get some info. on all the stuff . like what all do i have to do with my h22a4 to get it to run. becuse i have no wires that came with the h22a4 or computer . just info like that
            Click here this will get you started I'm not 100% sure but you are going to need to get the ecu for that h22. I really don't think f22 ecu will even run it. But if it does your not going to have vtec and its going to run like crap. Hope this helps you some.
              what ecu do i need to get that will run my car and let it hit rev and vtec. need some help on this one
                P13 is the stock ECU. Anything else you read about requires modification.
                It WILL run on the P06 (stock Accord ECU), but you obviously won't have vtec.
                  To run the 5 spd you will need to remove the old auto mount and weld up the 5 spd mount.
                    you mean pt3/pt6? p06 is obd1 dx/lx civic . chipped and vtec converted p06, or chipped p28/p72 will also work
                    Retired 1990 Accord LX Coupe
                    Project 240SX
