f22 starting problems *VIDEO INSIDE*
    This is what happen before i changed the cap and rotor on the dizzy. After i changed those things it starts better but still some hasitation. I was told it could serval things either main fuel relay, igniter, or coil. The spark plugs and wires are only 5 months old so i dont think it can be those.
    http://www.youtube.com/watch?v=t0e8cKpQ3zM
    clean ur iac there a diy on the diy section it will help on start up and double check ur work
    4 door ex-l
      YOu sure you put the firing order in right.
        Yea, that reminds me of improper timing/misplaced plugs. Double check with your manual. Also, dont be so mean to your starter! 20-30 seconds and stop, you know theres a problem.
          Fuel pump relay, or spark plug wires.
          Mine does this every now and then, and if you just leave the key on for a few (like 5 min) it will start, if your spark plugs are not in right, when you are cranking like that you are filling your cylinders and exhaust manifold with gas, and if it catches a spark BOOM, you can blow out your muffler.
          I did this on my nissan 280z, it was BAD!
            i'm pritty sure i put the plugs in the rite firing order.
            #1 the bottom closest to the radiator
            #2 rite above that
            #3 the bottom closest to the firewall
            #4 rite above that
            and i dont crank it like that all the time. it doesnt do that anymore since i've changed out the cap and rotor.
              1,3,4,2 Thats the firing order. And your firing order sounds wrong unless i am picturing it wrong.
                correct
                dizzy looking from the passenger side:
                firewall 2--1 radiator
                ..........4--3
                and the engine standing in front of the car
                4-3-2-1
                edit:
                Retired 1990 Accord LX Coupe
                Project 240SX
                  Originally posted by blackice
                  that is how my wires are rite now so i dont think its the firing order.
                    Ive heard that before, and it wasnt on a honda, it was on my previous saturn, the injector was clogged causing it to sound like it was mis firing, maybe give those a good clean and see what that does. Other thing you might wanna take a look at is the vacume lines, see if they are all in tact, make sure there are no leaks.
                    90 Accord EX F22a1 Auto R.I.P.
                    2011 Mazda 3 Hatch 2.5L GS sport HELLO!
                      i dont think its clogged injector becuz the i just notice the rpm started jumping a lil bit when i was going about 70 and it was around 3.5 rpm's. i'm really starting to think its the igniter.
                        check ur coil before ur igniter.
                        F22a1-->F22A-->H22A-->auto-2-5spd-->K20 6spd-->F22C 6spd RWD-->4G63 6spd AWD-->K24 6spd????
                        Sold to: blackice, Myothercar, Rennat, Ilikebigbutts, HA91, DA92CB7, accord91lx, Cb7GHOST, Gemini, whiteaccord92,Warudakumi, jhondayaaj
                        Bought from: 93twodoorLX, Datmofo, g7kobayashi, accord_inspire, Accord SiR, Kurobei, UK-Accord, phreakish93, RENR, k-mart
                          Shit, did you crank that long enough?
                          wat?
                            how do i check the coil to see if its faulty?
                              put in a differnt dizzy and see what happens,, it sound like the coil to me with maybe 2 plug wires crossed.
                              "Self Renewed"
