gas for h22
    gas for h22
    Hey, a friend of mine told me that a h22 engine has to be run on premeium gasoline. Is this true?
    91 Coupe-Under Construction
    From my experience anything lower than 91 octane with a stock ecu gave my knock sensor problems. Running a chipped ecu and wideband i was seeing much leaner afr ratios comparing 89 and 91...best bet is to run premium only. 10.6:1 compression on a jdm h22 is pushing the envelope imo. If the compression is much higher you start needing race fuel or a very good tune.
    Retired 1990 Accord LX Coupe
    Project 240SX
    Originally posted by chillin943
    anyone kno if i can just make a hot wire for v-tec off the horn??
    Vouches: Bought from: smseagren83, phatdoughnut, uk - accord, lucid, iamnemo, accord_inspire, 2point6, chopstickz, djcaz_aom, rosko
      If you aint running premium you shouldnt be driving anything with high compression.
        High compression (anything over 10:1, with factory tuning) and forced induction should ALWAYS use the highest octane gas available.
          I run 94 on my H22 and it was tuned with that gas, but I think when I get in re-tumed this summer I'm going to use 91 just because it is more readily available and it's cheaper. I only know of a few stations that have 94 octane so when I'm low in gas I'm afraid to put in 91
          SOLD!!
          Boosted H22
          375whp 298 ft/lbs at 15psi
