Hi all.
I hate being a newbie.
Ok, realistically, I am not a newbie. I have been on other forums, and now that I have found one specifically for Accords, I think I like it.
I hate being fresh to a forum.
I found the information that I needed, I hope. If anyone else has any input please chime in and say so.
My car revs to ~3500 and then its like a rev limiter kicks in. I read on the (click here first) thread, and saw that someone had a wiring problem with their injectors. This was the last entry on the first page.
WHAT I DID:
I was in the middle of a tranny swap (M2S4), and decided that I wanted to try starting the car to make sure it would run. When I did, the car was acting like there was a rev limiter.
I have a CEL, (or MIL if you prefer) and the d#$% ECU will not give me any codes. (I know about the diag connector in the passenger kick panel.)
All I know is that when I rev the car it stalls and hesitates at +/- 3500 rpm.
I replaced the fuel filter and that made very little difference.
SIDE NOTE:
I have the MSD cap and Blaster2 coil conversion, and noticed that a few times the rotor was arcing to the botched up wiring job that I did underneath. I resoldered that and ended the problem. I checked the Ignition mod at work, and it tested fine.
Could this have done any other damage that I have over looked? I cant find blown fuses, in either of the 2 boxes, nor can I see any wiring that got pinched in the bellhousing. I am at my wits end. Someone offer me some advice?
Thanks.
Tuna
WHAT I DID:
SIDE NOTE:
Thanks.
Tuna
