I'm about to change my fuel filter and I read to relieve the pressure take out a fuse then crank the car until it shuts off. But none of my fuses are lable fuelpump or fuel anything. I checked under the dash and under the hood. Anyone knows which one it is.
Where is the fuel fuse?
i usually just pop off my gas cap, put a rag over the bolt and slowly unscrew it...Retired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
i change mine about two weeks ago and just take off the gas cap
and then just loosen the bolts very slowly just a little of gas will come out
when you are done and about to start the car it will take like 2 or 3 cranks and it should start up....good luckH22 fund = 3000 hopefully soon My Member's Ride Thread
Canon XTI | 28-135mm IS USM | 18-55mm kit lens | 50mm 1.8 II
