air fuel ratio
    air fuel ratio
    how do i change it? my car is running SO rich that i have oil in my spark plugs. besides buying a vtec controller, i need to change it quick.
    running rich means you have too much fuel...
    if you have oil in your spark plugs i'd check your valve cover gasket and o rings.
    and what does a vtec controller have to do with anything?
      A VTEC controller wont do jack. If your car is runnign rich do a tune up and see if that fixes it. Plus change your VC gasket since you have oil in there.
        p.s. you dont need a vtec controller, as your car doesnt have vtec if its the f22a4 you say it is.
          Oh wow......
          1992 Accord LX - SOLD
            must not flame rofl . you are gonna need to do a lot of research man. but to get you started look at this link. it's the most likely reason you have oil around the spark plugs and shows how to fix it...http://www.cb7tuner.com/vbb/showthread.php?t=9300 like the other guys said if you in fact do have an f22a4 you don't have vtec so a vtec controller is worthless (imo it would be worthless if you did have vtec). also if you do feel your car is running rich a tuneup may help, along with cleaning out the iacv, checking your egr, o2 sensor, and catalytic converter to make sure they are operational. after that if you have any major modifications a chipped ecu with a tune tailored to your car will help with you running rich (and if you do have a swapped engine it will do the job of a vtec controller plus more haha)
            Retired 1990 Accord LX Coupe
            Project 240SX
