How to hand-rotate engine
    I'm nearing the end of my preparations to try and start my 91 LX that's been sitting in storage for a long time. I want to get some oil in the cylinders and hand crank the motor through a few revolutions to help lube it up before I try to start it, but I have an issue.
    This is dumb question, but how do I access the crank bolt to turn the engine? I think this is one of those things that's so obvious to most people there aren't any threads or videos on how to do it... So, a little help would be appreciated. Thanks!
    Find an appropriately sized socket and turn the P/S pump by hand.
    MRT
    sneaky motherfucker
      Forgive my noobness.. The power steering pump? How does that rotate the engine?
        19mm and breaker bar : turn the crank at the bottom by your driver front tire.
        Originally posted by Makaveli2k
        Be a man. Grab on the crank pulley with one hand, hold some chloroform over the air filter and "Shush it to death".
        Originally posted by Accrdkid
        Hey did you earn your Red Wings? Red Wings being you muffed dived that coochie and tasted copper and got the red mustache.
        No matter how far you go, the same path lies in front of you. "ユメクイ"
          The PS pump is connected to the crank by a belt, so technically that would work. However, that's not the way I would do it.
          There is a hole in your plastic splash shield that will allow you to fit a 19mm socket on the crank pulley bolt using an extension. I've been able to turn it with a ratchet, so a breaker bar isn't really necessary... it's up to you.
          You should only turn the engine in the same direction that it turns when running. It is not advised to turn it backwards (though I have... it's not smart.)
          To make things easier, remove your spark plugs. That way, you're not fighting the cylinder compression.
            deev is right take out the spark plugs (i forgot that part) and it is a heck of alot easier. i use the break bar for more room and i don't have a long handle ratchet.
              it would help to have the driver side wheel removed, but youll see the star-shaped hole that you can push a socket through.
                Excellent, thank you guys very much! Man this is exciting--I'm almost at the point where I can try to start it!
                  make sure you turn it
                  counterclock wise
                  remove the wheel
                  just 19mm socket and small breaker bar
