#1 | |
Administrator
EXT: Upgrading Wiper blades from newer Hondas
I've had this idea for a while now. It seems like it's working well.
I like the beam style of blade. It seems to wipe and perform better. But, Rain X or Bosch run $20 each, so $40 every time you want new blades. After some research, I realized that the newer Hondas had this I beam style, with replaceable inserts. I had the blades leftover from my moms old 08 Accord, and the passenger side works well. Le video: Drivers side: 76620-SLN-A11 for the "beam" $27.88 Rubber included, good to go 76622-SLN-ALL for the "rubber" $5.75 Passenger side: 76630-TA0-A01 for the "beam" $free, already had it 76632-TA0-A01 for the "rubber blade" $5.28 I'm particularly proud of this one. Nice and cheap and a good upgrade.
MRT 37.5 MPG, AC on, cruising at 80. 30.0 MPG, AC on, aggressively driving around 90. 27.5 MPG, no AC, cruising at 90 with occasional gridlock. 40 degrees Fahrenheit Lots of DIY videos specifically for our car Get some awesome wipers! <-- It's a DIY Quote:
#2 |
Master Of Posting Nothing
Are these similar to the "uni-blade" style blades? They are smoother, at first, but I've found that their edges skip and jump after so long. I'd say once they're 6 months old, they're no longer as effective.
I'll have to look into these and see if they're any better.
#3 | ||
Administrator
I had that same problem with the beam style blades of rain x, like this: ![]() I'm hoping to get that 6 good months, then get it back, for $10 instead of $40. Also it looks cool as fuck.
#4 | |
Administrator
![]() Edit: I have no idea if this is working. The Internet at my school just slowed way down.
#5 |
how much do the inserts cost? Do you have to buy from Honda? I dont remember seeing any sold in stores yet
![]() Members' Ride Thread :http://www.cb7tuner.com/vbb/showthre...82#post2939682 My CB7 Tribute Vid..https://www.youtube.com/watch?v=XqWFstSzLH8 Track ready EK..https://www.youtube.com/watch?v=IoYKsoL0i7M |
#6 | ||
Administrator
They were $5.28 and $5.75
#7 |
Did you price the insert holders themselves?
I feel like this is, essentially, a permanent arm and you just replace the inserts as opposed to replacing the entire unit. Granted, it's cheaper, but I feel like these will still skip and chatter after 6 months or so. I might be wrong.
#8 | ||
Administrator
I updated the main post with prices. This thread also has the benefit of saving the parts numbers. I had originally just looked for the correct size inserts and found the part number. When I took it to the dealership, he could tell I pulled them off a fit ![]() Edit: Re read your post. I'm hoping this is a permanent arm. It would be nice.
#9 | |
Administrator
I updated the main post. The drivers side I ordered came as one complete piece, so I didn't need the insert. I'll probably keep it, that's a free drivers side wiper!
#10 |
I just use Michelin Stealth Hybrid wiper blades. They are a combination of the both and they're only like $10 bucks each at Costco. I've had them for 2 years now and still running perfectly good.
![]() 1993 Honda Accord EX ![]() |
#11 | ||
Administrator
Also, I don't think Costco sells them anymore. I was just there and it's either goodyear or anco.
#12 |
GeoffM, is that Go-Pro cam strapped to ur head? lol
Great Video, the newer style wiper looks alot better, nice edition to our rides. Whatever wiper you use, I suggest that you use the liquid form of Rain-X on your windshield too. Especially in the winter months. It helps make ice not "stick" to your window, much easier to clean when your freezing your balls off in the morning. I love this stuff, and use it on all my windows, headlights(OEM Glass) and side mirrors. I barely use the wipers on my car with this stuff on.
#13 |
I like the way the 08 wiper arms look in comparison to the store brand beam type. This might be something I look into doing soon. Thanks for sharing the info with the community!
#14 |
Which 08 Accord trim these part no. came from. I'm interested on doing these but I can't find the driver's side. The passenger side match though. Just want to be sure all part no. fit our cb7.
![]() Last edited by 9tAkord; 09-23-2012 at 02:36 PM. |
#15 | ||||
Administrator
![]() I use the rain x washer fluid. Works very well, but every year I still find myself out there chipping away at the ice. It does work somewhat as a de-icer though. A thorough soaking then go out to chip. Comes off much easier. Quote:
I don't know what the guy pulled the drivers side from. I think there is a way to look it up off the part number.
#16 | |
Administrator
The drivers side is from something different. I don't know what. Only the passenger side from the 08 Accord will work.
#17 |
i like the idea. It just sucks that you will have two different styled wipers. i tried doing research to see if there was a perfect match size for the blades but they dont match our car. The 08 accord drivers side is 650mm and ours it is 600mm. its only a 2in difference but i dont know if it will stop the wipers from working on our cars.
#18 | |
Passenger side is from '08 Accord
#19 | |
Administrator
I've run into an odd problem with these.
Occasionally (keyword right there) the drivers side one will go a bit too far and hit my trim. But only occasionally. The rest of the time it's fine.
#20 |
Infinity QX56 wipers................. own any other wiper
and they are 24,19 |
Thread Tools | |
