Hey everybody, how do you remove a lug nut when the socket ( 19mm) meant for it is to same, and the next size up is to big?
Wheel Lug Nut removal
I always use a 3/4 inchMRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
somebody probably replaced them at some point. try imperial sizes, as they usually land just in-between the metric sizes.
It should only be a 19mm or 3/4.
Sounds like the corners have been rounded over, so that the flats are slightly bigger.
Try tapping the 19mm socket on with a hammer.
My 5.7 LS1 Holden Ute
13/16 is an oddly common lug nut size, which is 0.813 inches (20.5mm). very possible, since thats what my old '91 had all the way around.
and if all that fails, go to sears and buy a lug removal tool. Its got teeth around the inside that "bite" into the lugnut as you hammer it on the lug. Then you simply remove the old lugs. We have to do this a lot at Discount tire since people are retarded and lose their wheel lock key
