Originally posted by 1990Ex
View Post
EGR block off, what do you do about the wires?
Originally posted by blackice View PostIf your egr valve was bad to begin with it will still throw a cel even after blocking it off. Go get a chipped p06 or p28.
Originally posted by Flatline View Postjust be careful. sometimes when you ground a power you can blow a fuse. and there isn't an inline fuse for it so it's going right to your ECU. so be careful. ill lose sleep if my idea fucks someone's shit up.
Originally posted by frootloops View PostI'll try that and see if it can be done without tripping a CEL.
and how would putting the wires together help not through a cel? i think the egr needs to be there unless you have a chipped ecuMaple50175 - you're annoying =P
but the idea is that when plugged in, you complete a circuit. when it isn't a complete circuit, the ECU tells you something is wrong (CEL) so if you complete said circuit without the EGR present..... no CEL. basically telling a blind person that everything is okay. but it isn't.
(Not trying to make fun of any blind people reading this. Just simplifying it.)
I have and idea on how to leave it hooked up and keep the engine bay clean... You can cut the valve off near the top and just keep the electrical part and part of the pin from the valve to fool the ECU.
Tap into the egr wires anywhere between where the connector is and the ECU. It would be easiest to do at the ECU as far as the wiring goes, except you'd need to run a vacuum line thru the firewall.
If you don't need the valve in place for the inspection police, you could easily mount it anywhere in the engine bay.
I have paperwork somewhere on fooling the EGR with variable resistors and some other electronics parts, it seems like a complicated PITA to me. Get a P28 or P72 is the real solution. I don't think you guys can tie the wires together or anything that simple, or we'd all know that by now and I wouldn't have found complicated instructions.
I will dig up that stuff if someone electronic savvy wants to take a crack at it...
The ECU senses valve movement only from the EGR valve's top part. The ECU gives the signal that allows engine vacuum to open the valve, and then gets feedback from the valve that it has indeed opened.Last edited by lucid; 10-26-2008, 05:54 PM.
The H22 Sleeper Sedan, updated 8/14
After 4 months down...It's back! and tucked.
Need a Swap or some work done in the DC/MD/VA/WV area?
PM me and get it done right!
Originally posted by Flatline View Postwell his sig is a pic of his intake mani.....
ok so why not put something smaller in between the wires instead of trying to connect a power to a groundMaple50175 - you're annoying =P
I wanted to change my sig to something else, so it's a placeholder for now.
Originally posted by slick View Postand how would putting the wires together help not through a cel? i think the egr needs to be there unless you have a chipped ecuOriginally posted by Flatline View Postbut the idea is that when plugged in, you complete a circuit. when it isn't a complete circuit, the ECU tells you something is wrong (CEL) so if you complete said circuit without the EGR present..... no CEL. basically telling a blind person that everything is okay. but it isn't.
Originally posted by lucid View PostI have and idea on how to leave it hooked up and keep the engine bay clean... You can cut the valve off near the top and just keep the electrical part and part of the pin from the valve to fool the ECU.
Yeah if it was a simple as capping the wires off everyone would have done it and this conversation wouldn't be happening.
found some useful info on EGR
http://www.asashop.org/autoinc/nov2001/techtips.htm
now I know why my cb drive like crap 1500-2000rpm, it almost feels like vtec kicking in after 2500rpm
we need some one to make for us block off plates, like this guys
http://www.custombilletworks.com/products.php
have them make like 20 of them, so they only cost like $10 each, time for group buy
rosko from this forum already cnc's them....http://www.roskoracing.com/EGR_Valve_Block.htmlRetired 1990 Accord LX Coupe
Project 240SX
Originally posted by chillin943anyone kno if i can just make a hot wire for v-tec off the horn??
