Originally posted by cp[mike]
cp[mike] : 1992 Accord EX
wow im gonna have to get a few of these lol i only have one fan right now and the a/c seems fine without a fan blowing on it
PSN ID's:Tidashoni
1992 Accord EX Coupe
My FS Thread
Originally posted by deevergoteBoosting with a carb is like being a sniper with a bazooka... it works, it gets the job done, but it's not the most precise method.
Originally posted by The G-ManYou could still mount them on the engine side of the radiator and it will free up *almost* as much room.
PSN ID's:Tidashoni
My FS Thread
Originally posted by The G-ManEh, you can adjust the way they rotate by wiring. Use one wire as positive, fan move s one way, use the other, fan moves other.
i installed it on the front of the condenser because its not something that should die or need maintenance anytime soon... get it out of the way, where i dont need to deal with it or its wiring ever. now my radiator can easily come and go without having to remove the fan or redo the clips.
plus theres lots of room now haha. gotta clear up space in case i ever add a couple cylinders
any updates mike?
PSN ID's:Tidashoni
My FS Thread
Originally posted by almostJDMany updates mike?
now wheels? anyways MOAR PIX pleaze lol
PSN ID's:Tidashoni
My FS Thread
Originally posted by almostJDMnow wheels? anyways MOAR PIX pleaze lol
anything touching a bushing is installed finger tight. it says not to tighten any of them until the car is on the ground. buuuuut with the height of this car, theres no way thats going to happen... so im going to put the springs & shocks in and drop the car on blocks, torque everything down, then put the wheels on.
more pics tonight.
ohhh i got ya lol sweet glad to hear your finally about ready to let her loose on the streets, just make sure to keep gps on it lol j/p
PSN ID's:Tidashoni
My FS Thread
i finished putting the suspension all together. shocks and springs are in, and the brakes are all bled ( <3 speedbleeders ). torqued and cotter pinned all the balljoints. i just need to set it on the ground and tighten a few bushings, and put the F & R strut bars on, then itll finally be rolling lol.
still need to do a valve adjustment and install the MSD/battery/ignition stuff.
sooooooooon.
heres some pics from tonight:
