Ugh, with a PCB plenum comes added headaches!
#1: the stupid studs in the runners for the IAB plate and plenum are shorter, so short that they sit at the level of the holes in the plenum, and have to be swapped out to work with the P13 stuff.
#2: the throttle body attached to a PCB will have the MAP placed on top, and does not come with an idle screw, so you will have to swap out TB's as well (if you are running your harness, that is).
For the heatshield gasket, I purchased the Golden Eagle version because shipping was free. Hondata wanted $18 to ship a piece of $40 plastic. I'm sorry, but no way.
