http://www.autospeed.com/cms/A_0059/...popularArticle
That's best I can do The pictures and layout of that site are better than having me cut and paste. Obviously, I didn't write that. I haven't even done it (yet... Mikey, help me electronics wizard! ) In fact, I didn't even find it. Icedplaya123 showed it to me. I'm just soaking up the glory of others
The basic gist of it is:
You can cut off your ignition with a button. Easy enough. A little flashing light says "hey, I won't run". Turning it back on is the trcky part (good thing!)
You have a magnetic reed switch that you can activate with a magnet... In this case, hidden in the case of a dead alarm casing. Without a magnet, and knowledge of where the switch is, you can't start your car (an no one else can either). Seems pretty awesome to me!
I plan on doing it as soon as I have time, so I'll be sure to post pics and do a writeup. If anyone else does it, or has done it, let us know!
