Supplies:
+Phillips Screw Driver
+Mesh Gutter cover from Home Depot ($2.00)
+Wire Cutters/Scissors
+SprayPaint (optional)
First Take off your front Grill by removing the 5 screws, there are two clips behind the grill holding it on still, get a screw driver in there and press on the top there is a release button and work them out of the clip (you may have to pull and work it out it can get stuck)
When grill is off take all the screws out of the back of it. Measure the mesh so its a little larger than the grill but will still fit under the chrome that you just took off and cut it. I painted my mesh at this point with some spray paint you can do that or leave it. Align it properly and cut small holes where the screws go through. Screw top and botton Chrome strips back on. Screw vent back onto car.
If you drop screws all the time like i do they just fall into the plastic underguard of the car. Just bang on that a few time and it should bounce out.
FYI: i didn't write this DIY. what i've done to my front grill is similar though. the only difference is that i've left my chrome strips off, painted the mesh black, and cut that plastic black strip that runs across the middle of the grill housing off.
