I bought a valve cover gasket kit from hondapartsnow.com and it did not come with the lower tube seals. I should have bought the Autonzone Felpros kit which I think does come with the lower tube seals.
ENG: F22 Spark Plug Tube Seal Replacement
worn lower tube seals causes the spark plug to have oil on and around the electroid.**Blk Housed Slut Crew Member #1**
ahhh this seams hardddd to do. i dont no if i can pull it off.**Blk Housed Slut Crew Member #1**
This past Monday, EricTheCarGuy posted a very thorough lower tube seal replacement video on his YouTube channel.
http://www.youtube.com/watch?v=wYU8qtPzQOY
Ignore his nagging. (For those of you who've seen his other videos, you'd know he's sick of that particular CB.)My pictures/photos will return soon...
Great DIY did this last ight.2013 Honda Fit Sport Alabaster Silver Metallic GE8
2013 Accord Sport Modern Steel Metallic CR2
CB9 http://www.cb7tuner.com/vbb/showthre...hlight=hostile
CR2 http://www.cb7tuner.com/vbb/showthread.php?t=197787
GE8 http://www.cb7tuner.com/vbb/showthread.php?t=199289
Just to clarify since there are differences in the video and this diy:
So there is no need to completely remove the distributor and cam seals (or mess with the timing belt at all)? He simply removed the top bolt, loosened all the 10's and 12's, and popped the whole assembly off, without any of that having to hold one side of the camshaft down nonsense. If so this certainly simplifies this for the noobs.
Bought from: TypeG,mak,CB7_ACCORD,ChampCoupe,Blackex
Traded with: Cb7xChun
Sold to: Rob_is_legend,DaddyO,daheavyking
Sedan MR Thread Coupe MR Thread Prelude Si MR Thread
My huge For Sale Thread
Originally posted by darkfusion42 View PostJust to clarify since there are differences in the video and this diy:
Also, I'd make SURE you have the assembly tightened down all the way. Mine was leaking and I couldn't figure out why. Turns out I'd tightened them to 11 ft lbs instead of 16lbs.Last edited by GeoffM; 03-19-2011, 02:43 PM.MRT
Originally posted by Tippey764I think driving your car naked will cause the engine to overheatOriginally posted by deevergotesneaky motherfucker
Did this today alone without messing with the timing at all. I think the act of setting the engine to TDC still needs to be done on account of the lash adjustment. My old lower seals crumbled when I tried to remove them.
All in all it was fun and only took me (a noob) about 3 hours, mostly because I could not find the torque wrench anywhere......
i think i'm going to add the vid to the first post. eric the car guy does it just like they do at the dealership. later.
Also, that video is in the beginner technical stickies.MRT
Originally posted by TypeG View Posti don't know what to tell you guy. i watched it done on hundreds of accords at my dealership. later.MRT
