h22 f22 starter compability?
    Auto F22 to Auto H22
    are the starters compatible?
    Should be. I dont see why not manual f22/manual h22 works. So I dont see why auto/auto wont work.
      Check the part numbers in a breakdown. Any Honda dealer should be able to tell you if they're the same.
      ~If everybody you knew jumped off a bridge...the bodies would pile high enough to break your fall if you jumped after them.~
      Project Deerslayer
      UPDATE: DEER - 2, CB7 - 0
      '93 EX 5-speed coupe
      Short ram intake
      Tenrai Himoto catback
      Smashed front end
        i do beleive so. Clutch/Flywheel interchange, Tranny and interchange so i dont see why startters cant.
        I might even have a h starter on my f tranny. I might even have a hybrid with the base part of it F and the round thing H.
        I am about 95% certain that they ARE the same
          Auto/manual starters are not the same. Its only compatible auto auto or manual manual.
            they are identical
              Originally posted by cp[mike]
              they are identical
              all i need to know, thanks mang
                ha!
                turns out i forgot to ground the starter to the body.
                grounded it out with jumper cables and the car fired right up y0!
                  from what i've been reading online auto/auto manual/manual is good, but does it matter on years as well, would a 90/91 manual work on a 95 manual H? I tried running part numbers through majestic's list but when i check diff years some show denso some mitsuba and only components where others show the whole thing
                  IG:worldboss_sanjcb7
                    it should i have a 90 auto with a 95 auto starter on mine
