i did a dash swap
    i did a dash swap
    ok i just did a dash swap my car is a 1991 standard and i did a 1993 dash swap auto in to my cb and iam useing my 1991 cluster i used the dash wire set up and i have no dash light or no singel light ??? do i need to change my cluster to a 1993 or change my wire harness back to a 1991
    just curious, why did you swap dash boards?
      x2, the dashboards are exactly the same!
      .............................-----------------93 Ex Coupe[/COLOR]-----------------
      My CD7
        Wow, that sounds like it was a bitch and a half to do!
        Anyways, are you sure everything is connected and there is nothing loose?
        Fuse, blown light maybe?
        when you say no signal light, do you mean no signal light in the bumper AND corner light or just no blinker light in the dash?
        3 CB's gone....
        1 WK Overland....
        Still miss the CB though......maybe one day.
          when swapping dashboards i usually switch harnesses and use the original one with the new dash...
          but anyway your two issues: you wont get dash lights if the dimmer knob isnt connected, and you wont get blinkers if the hazard button isnt connected.
            no every thing works but the cluster isnt giving the right singnal like the oil light will be flashing as my right or i think my battry light will be flashing i dont know what to do but their is no intiror light what so ever
              match the harness to the cluster youre using, which id recommend matching both to the original. since the 93 has some different indicators...
                same thing i did.
                JDMRIDES.ca
                  Originally posted by lowakkord
                  same thing i did.
                  did u have the same problem as me or ??
                    i dont think your understanding....
                    They are telling you, use the 91 dash harness in the 93 dash.
                    -RIP Eric Hall. Miss you brother-
                    newskoolhippy (10:53:37 PM): i want to see a pic of you with a hard-on to prove thats your cock
                    newskoolhippy (10:53:56 PM): i need to see your face in the pic
                    newskoolhippy (10:54:07 PM): with todays paper in the picture to prove your taking it now
                      ok so i did what u guyz seid it worked but one problem my cluster light dosent work when i turn the head light on and yes i plug that light thing what could it be
                        got a bad dimmer switch or a blown fuse?
                        Retro!
                        Hater
