ABS brake bleeding
    ABS brake bleeding
    I know this can't be done by anybody except Honda, so i was wondering, how often does this system need to be bled or serviced? I've never changed the fluid in that reservoir since i've bought the car i believe. But have flushed the regular master cyl. reservoir many times. And the big question, how much would it cost to have it serviced?
    no one knows anything?
      all i know is that a new ABS master thingie is like 1000 dollars, lol
      is the light coming on?
        If you just bleeding the brakes, it should be the same i would assume, i would just make sure the car is off when you bleed it so its not kicking in the ABS. Make sure you clean out the master cylinder/replace if neccessary, it there is alot of crap in there, i would suggest replacing it if you need to bleed the brakes anyways.
        90 Accord EX F22a1 Auto R.I.P.
        2011 Mazda 3 Hatch 2.5L GS sport HELLO!
          to bleed the m/c and calipers its standard procedure, but to bleed that master block thing of craziness id imagine bring it straight to the dealer, or call and ask for a price there...
            no the ABS light is not on, its working fine, its just that i've never bled that part of the brakes EVER on my car, so i just figured the fluid in there needs to be flushed out. I mean, is there a recommended time interval to service the ABS system?
