Pon Ecu.
    Pon Ecu.
    Ive tried three tcu's they wont let me shift out of park is there something that i need to be doing?
    Cali.Dumps.Harder.
    I can press the shift engage button on the shifter to shift it out of part and it will go to all gears but once i go back to park it wont come back out.
    Cali.Dumps.Harder.
      Neutral safety switch.
        Cali.Dumps.Harder.
          Thats probably whats bad.
            I have three of the tcu's they all do the same thing. but when i go back to my stock everything works fine...
            Cali.Dumps.Harder.
              Oh... I didn't realize that your stock made everything fine.
                Yes. it does. Any other things to be i have three of them i don think the tcus are bad i have three of them.
                Cali.Dumps.Harder.
                  the other three, what are they from?
                    the jdm sir accord. CF is written on one of them.
                    Cali.Dumps.Harder.
                      which was the 98-00 if im correct.
                      Cali.Dumps.Harder.
                        what i found on wiki...
                        The Accord Euro R / Torneo Euro R was also in 2001, featuring a 220 hp H-series (h22a7) engine, and 'R' features such as Recaro seats, LSD, sports suspension, and titanium gearknob.
                        Cali.Dumps.Harder.
                          the JDM TCUs dont properly unlock the shift lock solenoid... couple minor wiring changes to make it work, the information is floating around out there. many ppl just ziptie the lock down, or wire it to the brake pedal. but no this does not mean the TCUs are bad.
                            zip tie the lock down? would that make it not stay in park?
                            Cali.Dumps.Harder.
                              it would stay in park, unless you moved it otherwise its like semi-permanently jamming a key into the 'shift lock release'
