F'N CLUTCH CHIRPING!!!! please... someone save me!
    ohk guys, heres the deal.
    when i bought my car, it had a loose clutch. so i bought a stage 1 for it.
    after installing the new clutch, i noticed that when i had the clutch all the way out, it made this annoying chirping noise. it was constant, kind of like a belt slipping, only chirping.
    well today, i figured out that it was my slave cylinder wasnt functioning properly. so i bought a new one, installed it, and guess what, it was a faulty unit. fucking A. for some reason it wouldnt bleed in.
    so i knabbed one of my bud's cb, installed it, blead it in, and guess what, it still fucking chirps. not as loud, but still loud enough that everyone can hear it.
    how do i make it end!!??
    GUYS, PLEASE help me figure this out... its so embarrassing/annoying/aggrivating
    "This truck is 100% sh*ts and giggles."
    "Speed has never killed anyone. Suddenly becoming stationary... that's what gets you." Jeremy Clarkson
    You're not JDM until you have a car built in ohio with tons of bolt ons from ebay.
    Disregard females, acquire currency
    BUS 62 AIN'T F'ING AROUND!
    Does it sound like its coming from the belt if thats not the case and the motor you have either a bad squeeky belt thats a tad too lose or your throw-out bearing actually old worn or on its way out.
      sounds like a throw out bearing? did you replace it when you changed your clutch? most aftermarket one tend to squeak or make noise after time
      Members Ride
        sweet now i know what to replace. to the thread starter, does this only occur when taking off from a dead stop in first? cause thats when it happens to me.
        THIS CAR DOES NOT BELONG TO ME SO STOP GIVING ME COMPLIMENTS!! although it is quite nice....
        Vehicular Lunacy At Its Finest
          yes i have a same noise but its not chirping more like a door with bad hinges creeping opening.. creeeeeeeeeeep.. yes happens every time i engage the clutch to move the car from dead stop funny thing is the throwout bearing is new and came with the XTD stage 3 clutch off ebay i don't know why its making noise already.. i knew i should of went with a honda oem one.. damnit..
          http://www.get-gifts-for-free.com/?ref_id=4810
          1992 Honda Accord 4dr 5spd EX- R.I.P 8/10/05
            most likely ur going to have to drop the tranny to get to the T-O bearing..
              yes i replace my throw out bearing. ill go outside and get a quick vid for u guys.
              you can see something wiggling to and thats where the chirp is coming from. its something to do with the slave cyl im almost sure of it...
              ill have a video up in a few minutes
                video of the chirp
                  what kinda i have a brand new slave for the stage 3 clutch and mine is making that sounds i guess its a cheapo and its going out..
                    i dont hear chirping, i hear a fluttery ticking? changes with engine speed? clutch related, not throwout bearing or slave cylinder...
                    take out that rubber plug and listen through the hole, is it loud and clear from in there?
                      yeah the vid didnt come out right at all.
                      basically, imagine that ticking as a high pitched chirping...
                      but its not coming from inside the trans.
                      its coming from the slave cyl. like, the end "part" sorry not tech savvy.
                      i can push it in, with my hand, just as if i were pressing the clutch pedal, and it stops. does that help any?
                        doesn't sound like the T.O.B.... sounds strange hmmm..
