HELP! Clutch pedal doesn't decompress!!
    Alright, so me and my buddy are driving home tonight after picking up some grub, and my friend tells me that the clutch won't decompress. So we pull over, park the car and lock it, bum a ride from a friend, and I just got back home.
    Does anyone know what the problem could be? It feels like the spring is gone since the pedal won't decompress. Your help is much appreciated.
    Always remember that only you can make your dreams a reality.
    Never forget that your style is all that matters when it comes to your ride, but be respectful to others who don't share your vision.
    Proud Alum of the University of Texas at Tyler, Class of 2010
    decompress? meaning lose pressure? or the pedal doesnt pop back up. did you look to see if the return spring came off the side of the pedal?
      It doesn't come back up. It happened at about 1AM and I didn't have a flashlight, so when we tow her back tomorrow I'll check on that.
        Check fluid levels sounds like a leak.
          ^^^^x2. Check especially around the seal in the driver,s side fire wall. Check it while you are checking for the spring.
            check your slave master cylinder.
              Sounds like a leak in the clutch system. First check your fluid level in the reservoir. If its low then chances are you have a leak. Second, trace the clutch lines until you spot moist lines/hoses. Same thing happened to me and it turns out it was the clutch hose. It leaks from the metal fitting that connects to the rubber hose. Cost about $25 from the dealer.
              ...adjust accordingly
                It was a clutch stab.
