I have a water leak, However I am having trouble chasing it down.
It is dripping from the drivers side rear block... It is dripping onto the inner cv boot on the drivers side, and then to the ground. It is coming from the area of the water pump(lower left of block), but it could be dripping higher and flowing down the block. I just want to clarify that the leak is on the BACK of the engine.
The weirdest thing about this leak is that it only drops water when the engine is off. It does not leak when the engine is running. and it leaks weather cold or hot. it is dropping about a half gallon of water every 2-3 hours it sits.
I am hoping someone can give me some ideas on what could be wrong, and maybe the simplest way to fix it ( and I am on a TIGHT TIGHT budget)
