Reusing a torqued head gasket
    i put my head on the other day, only to JUST find out that i forgot the dowel pins.
    i will NOT run the car without the dowel pins, so i need to pull it back off...
    i sprayed a layer of copper sealant on both sides before i torqued the head down onto the new OEM gasket.
    its never seen pressure, only torqued down once... can i reuse the gasket? id use the sealant again.
    nevermind, its not even worth the chance to save $60. new headgasket :\
      lol. how much did it cost to fix your head/valves?
        hmmm
        $140 : 8 ex valves
        $90 : installation
        $15 : few seals
        $110 : 2 headgaskets :
        $20 : 2 new rocker arms
        $375
        sucks, but good thing i had to pull it apart or i wouldnt have caught the rocker arms before they caused other damage.
          wait a second....mike paid 90 for somebody else to install something?
          am i missing something here?! :[
            It was his valve job he paid someone else to do. Sell the used HG on ebay mike =P hahaha.
              machine shop. they grind the valve seats/valves, measure/grind stem length, and vacuum test it to make sure its sealed perfectly. for $90, i dont have the time or tools to attempt that.
                ohhh, that's completley different from what i was picturing.
                  I had the same question awhile ago with a cometic head gasket, I had assembled and tore down the motor about five times while checking piston to valve clearance. I emailed them and they said that I should be fine to use it as long as it hadn't been ran.
                  www.roskoracing.com << Euro-R manifolds/adapters and H22 parts
                  >>check out my H23vtec build thread...
                  http://www.honda-tech.com/zerothread?id=2030543
                    Yeah, I think mike would be unstoppable if he had all that equipment in his possession. lol.
                    Been a long time. Still alive...
                      EXACTLY, and thats the ONLY reason whats hindering me from doing BIGGER jobs!
                      TOOLS....
                      needed:
                      valve spring compressor
                      ridge reamer
                      Brake Cylinder Honer ( not cheap )
                      tap and die bits ( set )
                      hub puller
                      piston ring tool ( remove/install )
                      NOTE: theres other tools needed I just can't think of them right off...but yeah...without the tools you need ( knowing how to use em ) you can't do the job! resulting in Paying a shop to do it! ( space needed as well )
                      and money dont grow on trees... BILLS suck!
                      MR Thread:
                        you dont need the super duper special valve spring compressor, just a simple 50 dollar one.
                        that, with basic tools is more than you would need rebuild a head.
                          TOOLS....
                          needed:
                          ridge reamer
                          hub puller
                          ridge reamer / spring compressor / taps & dies are hand tools that arent hard to get... i was more referring to the precision machining equipment lol. and why would i need a hub puller and piston ring compressor to do valves?
                            I think he was just referring to the right tool for the job, in a general sense.
                              Howz bout you shut your pie hole
