rpm's stay suck when in neutral
    Well i have this problem with my car. i was searching though
    the forum and i don't think i found anything on it, but i might be
    wrong. i do not know what it is call so if you have links or the same
    problem and you fix it. can u please help me out thanks
    well here is the problem when i am driving and i put
    the car into neutral (5 speed not auto) well the rpm's stay
    stuck there and i have to give it a little gas or move the petal
    back so the rpms can go back down to normal.
    if you know what it is called also let me know
    H22 fund = 3000 hopefully soon My Member's Ride Thread
    Canon XTI | 28-135mm IS USM | 18-55mm kit lens | 50mm 1.8 II
    sticky throttle cable?
      That's what it sounds like to me.
        what if you pull the pedal up with your foot? if that makes the RPMs go back down, may be a sticking throttle cable, like they said.
          Yep sticking throttle or throttle cable out of adjustment.
            thanks i guess ill try to change out
            the throttle body and see if the works
            ill let u know if that works or not
              DONT GE NEW THREOTTLE BODY!!!!!!!!!!
              just get a thro tte cable from a local junkyard
              lisa is long gone, but sophie is here!
              i got a good feeling about this one
              im going to have to
              __________________________
              |...OVERNIGHT PART'S 4RM....||'|";,__
              |..............JAPAN.................|| ---**-)
              |_..._...____________======||_|_|__--]
              check out my mr thread
              http://www.cb7tuner.com/vbb/showthread.php?t=106541
                I am not going to buy a new throttle body
                I all ready have one. it because my motor when out so i put in my other
                motor from my auto and it is doing that now it was doing that in the
                auto so maybe it is the throttle body. so i am going swap
                the throttle body from the manual motor to this one
                and see if that helps
                  YOu dont need a new tb lol. Just get you some carb cleaner or brake clean whatever and spray around the throttle body to clean it a bit. As for the cable try adjusting it first and see if that helps it only requires a 10 or 12mm wrench.
