I've never taken a look at my drum brakes in the back, they could be toast, do they have a sensor or something that could trip the red brake light to stay on in the gauge cluster? I've tried everything and that light just stays on. Oh, also my ebrake doesn't really work, it clicks and all and feels like it's pulling on something, but the car still rolls.
Brake light stays on, rear brakes the problem?
I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
"Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
CB7: The Movie TEASER VIDEO
Tags: None
Is it the break light under the Fuel and TEmp gauge? becuase if it is, thats your break LIGHTS at the rear of your car. either one of your bulbs are out or your like black relay delio is toast back there. check out the bulbs and such. Goodluck, on just a heads up if u want those black box thingies you can ind them @ a Dealer for $80+ CND or just go looking around in a junkyard hahah. enjoy. If your sensors are out then when u press the pedal one side of the lights wont come on and such. have fun! took me a couple days to figure this out
Oh, also my ebrake doesn't really work, it clicks and all and feels like it's pulling on something1990 Accord EX -Stock to no beyond
Originally posted by yeamans17you'd better soak the nuts in pb blaster, otherwise you'll snap them off
Vouch - | gloryaccordy | aznkid.com |
as mentioend check your brake fluid first. There is also an e-brake switch that can cause that but check brake fluid first. quick and easy.
brake fluid was the FIRST thing I checked. any other ideas?I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
fluid full, cap seated. Any other ideas?
maybe the little sensor in the cap is messed up?? any way to test it?I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
Figured out the problem, thought I'd let the rest of you know incase anyone else is having this problem. It was the little sensor in the brake resevoir cap. Just unplug it and your good to go.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
Originally posted by TorqstrFigured out the problem, thought I'd let the rest of you know incase anyone else is having this problem. It was the little sensor in the brake resevoir cap. Just unplug it and your good to go.1992 Accord LX - SOLD
heh, valid point. I never checked that. But I'm assuming my brakelights still work, I mean I don't think the little fluid level sensor would interfere with that, but I could be wrong.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
your brakes obviously need real work anyway... dont worry about the light, fix the issues and see if the light goes away. disconnecting the sensor doesnt fix the problem, it just hides it.
um...it's just the sensor for the fluid resevoir. it's probably just a faulty sensor.I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
