timing belt kit off ebay
    wut do yall think bout the ebay timing belt kit that they sell on there. i think the makers of it are koyo gmb and sum other one i cant remember. but they say that the makers they have are the same ones honda uses to make their stuff. but who knows if those ppl tell the truth. well any info on that thank u in advance
    cant wait till im all done
    There are only two brands that Honda uses for their t-belts; Unitta and Gates. I have never found Unitta belts available from any aftermarket supplier, however some parts stores carry Gates belts...so those are fine. All that other aftermarket stuff is garbage. As for the waterpump...get OEM, period.
    00 Jeep Grand Cherokee 4.7 V8 4X4
    92 Honda Accord LX
    95 Honda Civic CX
      I would see what Honda has for T-belt kits first. I wouldnt trust aftermarket from ebay.
        I purchased my tensioners, timing belt, balancer shaft belt, water pump.......everything but the seals off of eBay. The seller was in Yakima, WA. and the parts are exactly like OE. I've had no problems and it's been about 20k since my last tb maintenance.
        Honest to god, I don't expect to have any issues......
        *edit*
        This is what I got
        1992 Accord LX - SOLD
          thanks everybody i found a kit online that came with all honda stuff but it didnt come with the tenisoners i called honda and they are almost 200 bux i was damn. i will prolly go with wut u got maroonaccord.
            *edit*
            This is what I got
            i can vouche for that seller.
            ive been to the store, those guys know what they're talking about and are pretty cool too.
              But why even replace the tensioners? In all my years of working on Hondas, and the hundreds and hundreds of t-belt jobs I have done...I have never seen a tensioner go bad. However, we do see aftermarket t-belt failures quite often. The point being...get the OEM stuff.
              92 Honda Accord LX
              95 Honda Civic CX
                i ONLY get oem belts. i only got new oem pulleys because they were H23, but other than that, ive never seen them fail (or even start to get stuck)
                  well i found a oem all honda stuff comes with:
                  TIMING BELT-14400-PTO-004
                  BALANCE SHAFT BELT-13405-PT0-004
                  CAM SEAL-91213-PT0-003
                  CRANK SEAL-91212-P0A-004
                  BALANCE SHAFT SEAL-91233-PT0-003
                  WATER PUMP-19200-P0A-003
                  POWER STEERING BELT-56992-PT0-J02
                  A/C BELT-38920-PT0-004
                  all this is about 145 bux i saw another one that didnt come with the power stering belt or the ac belt but came with the valve cover gasket and the spark plug tube seals and it was a lil more not to much like 10 20 bux. well u think thats a good deal?
                    My car f22 has over 220k, so I figured it was just cheap insurance....
                      thats how i think maroonaccord i rather replace it all why im in there.
                        i buy everything from the dealership. some of the aftermarket parts may work for some, but i'd rather not gamble. after working for honda, i've seen a lot of things first hand. later.
                        Avoiding dirt at all costs
                          if you buy off of ebay, make sure they are all OEM replacements, i wouldnt trust too much aftermarket from ebay.
                          1990 Accord EX Sold
                          1995 Accord LX V6 Stored
                          1999 Accord LX Daily Driver
                            i would only let genuine honda parts touch my car, but hey... thats just me!
                            "Up Down, Slide To Slide"
                            Members ride thread- ]http://www.cb7tuner.com/vbb/showthread.php?t=63019]
                              Genuine Honda parts are cheaper than a new motor... When it comes to stuff like the timing belt and water pump, I wouldn't get anything else. For things like power steering and AC, I would save a few bucks and get the cheapie stuff... if those belts break, the worst that will happen is that I won't have those accessories (I don't have them right now anyway!)
                              ALWAYS weigh the cost of the cheaper parts with the potntial issues that may arise because of them. If the cost is significantly less, the fitment is OEM quality, and the risk is low, go for it... If there's a $40 difference, the parts may not fit properly, or failure may destroy something MUCH more expensive, it's worth paying the extra.
