OK so I wired the dizzy up and now the car won't crank over, even with a jump. However, the no-crank problem started BEFORE I wired the dizzy/coil up. Also, the car doesn't beep when I put the key in the ON position, and only the battery light lights up.
Does anyone have the interior fuse panel diagram? And could this be the result of a fried ECU? I've been trying to start my car for the past 2 days and all it's been doing is cranking. Could that have fried the ECU/some wire?
