Picture of your alternator tensioner please!
    Somehow I think my alternator tensioner flew off the other night! Now every time I tighten up the belt it just goes slack again after I give the car some high revs. I still have the little bracket on the front of the alt where the tensioner was, but I need a picture of it so I can see about fashioning something else to work just like it did.
    I read somewhere that marijuana effects the memory. For some reason I can't seem remember where I read that. -- max sideburn(aka torqstr)
    "Those who would sacrifice liberty for security deserve neither." - Benjamin Franklin
    CB7: The Movie TEASER VIDEO
    please i really need this info. just snap me a picture of your tensioner real quick. Thanks.
      haynes manual?
        can't find mine right now......but I know somebody has to have a picture of that part of their engine bay lying around.
          hmm I dont think my car has that tensioner
          93 Accord LX Sedan (sold)
            i dont have the tensioner..mine was missing when i got the car so whenever i need to tighten my al. belt i just get like a long pipe or corwbar of some kind...and wdge it between alt and the header...and put pressure on it till tension feels ok on belt and tighten the botoom screw of the alt.always worked for ...ive done alott
            it helps to have a friend so someone can tighten while other holds the tension
            My Members Ride Thread
              This would probably be fine.. as long as you avoid overtightening the bolt, then you'd be fucked...
              I could try to draw a picture, but its not gonna look right if the pic isn't 3 dimensional.. Look at your tensioner for your power steering... its pretty much the same deal.
                yea dont overtighten i didnt say that
                  hope this helps .... i could get i pic or i would have
                  click to zoom
                  R.I.P. 6-10-07
                  (\__/)
                  (O.o )
                  My Rotor DIY
                  I'm not perfect i will make mistakes if i do just point it out to me
                    I don't know why a tensioner would be missing unless the person who replaced it before was a Moron. Are you sure it's gone and not just hooked up right?
                    EGR Port Cleaning http://home.comcast.net/~em-engineering/T2T013.pdf
                      How did your tensioner fall off? Hmm if you can tighten the tensioner is still there or are you using the single 14 to hold it? Its basically a long screw with a hole in it with another screw that goes to the bottom of the alternator so it holds the adjustment in place.
