check your clutch relay fuse the 7.5 that shit can also cause your car not to start . Had that experience the a/c clutch relay fuse under the dash that shit cause my car not to start.
Diagnosing a no-spark situation
Originally posted by h22sparklecheck your clutch relay fuse the 7.5 that shit can also cause your car not to start . Had that experience the a/c clutch relay fuse under the dash that shit cause my car not to start.
Did you disassemble the dizzy at all? and possibly reassembled it 180 degrees out, Although it should still have spark even if it was.
We had a case in at work the other day where an accord wouldnt start, It would crank but not start, found the problem was the battery not quite strong enough to create spark as well as crank at the same time.
My 5.7 LS1 Holden Ute
Originally posted by cp[mike]do you really think ive tried all this and havent checked the fuses?
BWUAHAHAHA! oh my god that totally reminded me of the new "office" episode where Jim is looking for those "hers chips" for that hot chick and the guy who sits in front of him asked if he had checked the vending machine and jim replies "no but we did check the copier and fax machine" hahhahahaH22 Prelude VTEC 92-96 200 161 10.6:1 87 90 DOHC VTEC 2157 JDM
Originally posted by 4CYLPOWER92I'm totally lost. What else does the coil need besides the voltage you tested for, in order to function properly?
Originally posted by evil_demon_01Did you disassemble the dizzy at all? and possibly reassembled it 180 degrees out, Although it should still have spark even if it was.
Originally posted by maroonaccord2.2lol Mike, I'd never assume that.....you seem pretty "on the ball" to me.
stopped off at the dealership on the way home from work today to talk to the techs there. i explained what was going on and what i tried. no useful suggestions beyond what ive tried already. im gonna try to work on it some today.
tried a whole new engine wiring harness from a working car, as well as that relay phatdoughnut suggested. no difference whatsoever. shit.
De ja'vu
I had the same problem. I extensively tested the ignition system to find my problem. Check my post maybe you missed something.
http://www.cb7tuner.com/vbb/showthread.php?t=42779
Good Luck
Jeff
Originally posted by So Cal DivinI had the same problem. I extensively tested the ignition system to find my problem. Check my post maybe you missed something.
Good Luck
Jeff
Originally posted by 90Cb7sleeperAny updates on this Mike??? i really want to see you get this thing running... I basically used you project as a model for my senior project when i did my A6 swap... so when my wouldnt start at first i was like oooooo shit!!! but mine turned out to be plug wires. Good Luck man!
