cracked piston
    cracked piston
    is it safe driving the car if its cracked? it smokes a lil bit...
    You have been defeated by a car with child locks, how embarassing...
    "I noticed my f22 felt "healthier" until it blew up." <Myk>
    bump, might be a piston ring
      well have you seen the piston? what color smoke is it? if its white then you have a bad headgasked or if its blue you probaby have bad rings or bad valve seals
      new ride
      07 cobalt ss/sc
        im gonna vote on bad rings its a typical thing
        the build and demise
        buy stuff i want a new car
          the smoke is white.. so can i still drive it and not boost?
            rip that head off and replace the gasket asap its a simple job you only really need the valve cover gasket the head gasket its self real easy 1day job not even
              yup if its blowin white smoke then you got a bad head gasket
              new ride
              07 cobalt ss/sc
                i took it to a shop and they took off a inlet line to the turbo and it was blowing white smoke in there, and also when you crank up the car its kinda lazy so they said its either a bad piston or piston ring. i just want to know if its safe to drive it with the problem.. my antifreeze is clear
                  is your oil watery ?
                  you could have a bad turbo seal you could be suckin in coolant
                    nah the oil is fine, the turbo is fine, its only oil cooled
                      do a compression test. later.
                      Avoiding dirt at all costs
                        i dont have the tools for that, maybe you can give me a second opinion when u see the car tonight
                          compression gauge is cheap from autozone.
                            that shit is like 15 bucks and dont put the adapter part in there that screws all teh way down in there the piece just how it comes on the hose will suffice dont add anything on it.
                              my friend said he'll bring his tester tonight. later.
