Rear Seat Removal, How?
    Hey Guys,
    I'm wondering how to remove the bottom part of the rear seat? Is there a trick on how to remove it? cuz I haven't figured it out yet
    95 Accord Wagon EX - Stock
    You have to really remove the top part of the seat first, to make the bottom easy to remove (although you could conceiveably remove the bottom of the seat if you could find the bolt).
    First, you have to remove the two side panels on either side of the the backrest. You pull them forward at the top to disengage the clips. Then you should be able to see where they bolt in. With these out of the way, you can remove the backrest (either 1 or 2 bolts per side) then you can finally get the lower cushion of the back seat out.
      Dam, I just wanted to move the bottom part so I can have easy access to the bolts that hold the side cushions. I guess I will do it the hard way, thanks for the info
        fold down the top, take out the four bolts holding it in. then you can get to the single 10mm holding the bottom section in. then you can lift up the back edge and it swings up and forward, and THEN you can take the side bolsters out.
          http://www.cb7tuner.com/vbb/showthre...r+seat+removal
          later.
          Avoiding dirt at all costs
