Car won't start. Just replaced battery. It will pop-start... bad starter?
    Just as the title says. I turn the key and I get *click*. Nothing. Won't crank.
    I pop-started it, and it started right up. Got it home, and *click* again.
    The only thing I can think of is the starter... I just spent $150 on a battery (needed one anyway) so I really don't want to drop another buncha money on a starter if that's not the problem!
    thats what crazyvtec93h22's starter was doing... threw his old one in and it worked perfectly.
      Damn... sounds like I'm dropping more money on the car today...
      New starter FTW! (I'm making it into an obscenity... )
        yup starter
          Wait!!! No!!!!!!
          I had a problem like this...it turned out to be the negative battery cable. It was rotten. I could jump start the car no problem and I was getting decent voltage on the old battery...I checked the wire and it was all caked through with that cyan powder. I changed it, it started right up, haven't had a problem since. I just don't want you throwing $70-80 at a new battery...check the wire!!!
          Originally posted by lordoja
            true... what i didnt mention was that i cleaned and redid the ground wires before trying the old starter again, and that didnt help.
            not having a good enough ground, the starter wont get full current and may not have enough power to crank the motor over...
              Just got the starter... were there automatic USDM H22s? The woman behind the counter didn't ask me if it was auto or 5 speed, and I didn't think to ask (I was hungry, and not really with it!) I have 2 connectors with nuts on them,and the one clip-on connector... Strangely, I only remember one. I'm about to go start removing the old one, but I figured I'd ask before I ran out there and got frustrated!
                The 97-2001 was available with an AT...
                  Ok, cool. Then I'm on track. I have the old one out, new one ready to go in.
                  I have to transplant the bracket for the radiator hose. That long bolt that runs the length of the assembly has to come off... will that change anything inside if I undo it? I don't want to mess it up!
                    nope
                      Cool. Good to go now
                      Thanks guys.
                        Ok... snapped off the main lead on the first one... got another one.
                        Installed it, turned the key... *click.
                        Now I have NOTHING. No accessory power or anything. Absolutely nothing whatsoever.
                        I checked all the fuses. None seem to be blown. What else could be the issue? I'm stuck... and really pissed.
                          lol. deev figured it out already.
                          dirty terminals pwnd him.
                            wow 150 on a battery....? any who yeah its ur starter........i had the same problem.......
                            ・オレンジ(デミオのオレンジがなかなかいい味を…)
                              ・ブルー(インプレッサみたいな感じのメタリック系が何
                              ・その他随時考え中…
                            ......今日までの道の愚かな米に屈辱を与えるためにHonda Accord は作られた。愚かな競争を従事させている間抹消されるところ倍数の敵ターゲット。CB7 Honda Accord 。道の王。自動車恐怖。........
                              just as glory said before same thing happened to me... except i didn't replace a battery and starter first lol...
                              negative battery terminal that was dirty and loose and not a good connection
