Few Questions,Help Please!!!!!
    1st off can you tell me what is supose to be pluged into the connector circled in blue?
    2nd can you tell me where that hose goes?I circled the place in red were I think it may go but im not sure can you tell me were it goes?
    3rd can you tell me were im supose to put the two wires for the IAB's because I dont see any place with pins to put wires?
    Thanks alot!!!!
    Thanks alot!!!!
    BEFORE I ANSWER this...what year cb7 is that..and is it a Manual or Auto...because I went outside to hunt down those problems you have..and
    for your first Question.....that connector goes to your Wiper motor..does your wipers work????
    the second and third questions...I will figure those out later on today..and come back on here..and help you mayne...BUT..if anyone else has solutions..help him out!
    from the first pic...it looks like you're missing the clutch cylinder resoviour....which means that must be an AUTO!! ( facing car: sits to the RIGHT of the Brake Master Cylinder )..I dont see that Clutch cylinder reso
    92 LX. A6 with GUDE bullfrog Cam. M2S4 transmission..Gutted H23 intake mani. The rest you will just have to find out!
    MR Thread:
      Which engine code is that... F22A1 / F22A4 / F22A6 which one????
      MR Thread:
        f22a6
        #1. yes, wiper motor. it connects to the other half in the very very very corner of the engine bay.
        #2. you see the speed sensor on the back of the transmission with the hose looped over? remove that looped over hose, and youll see the two open nipples... the two lines on the crossmember get connected to the two lines on the speed sensor.
        #3. you see the round plunger for the IAB? the red vac hose that you have connected to it should go to a black plastic box mounted underneath the intake manifold. the other side of the box should be connected to a vacuum nipple on the back of the manifold. the IAB plug connector is on this black box... hard to see from above.
          Originally posted by cp[mike]
          f22a6
          thanks for the Collab Mike...I had just came back in with the info...from looking at mine..to help this guy....
          MR Thread:
