"BRAKE" and "ABS" lights came on today
    WTF??? I think I'm due for a pad change possibly; but when I apply the brakes there is still decent pressure which isn't usually the case when the pads are low. Plus it's not making that grating low pad noise. What's the deal?
    Originally posted by lordoja
    CHeck your brake fluid levels?
      brake fluid levels fine?
      it takes about 5 minutes to pull the wheels off and check the pads so let us know! and just take a look at the ABS sensors while your in that area
        What should I look for when checking the ABS sensors in particular? And if my fluid is low does that mean I might have a leak somewhere? I've been looking to get SS brake lines anyway.
          Not really. Sometimes it just leaks out of the MC reservoir or its always been low.
            my be a cog if the res is pushin fluid out the top that means there is to much preasure build up
              What's a cog? I'll check it out when I get home tonight.
                Ahhhhh came back today!!! I wanna rip ABS out!!!!
                  check the fuse and other wiring?
                  Hi, I'm Shippo and I have a problem. I keep buying CB7's.
                    mmmm, yes. thats why i did.
                    if you take the wheels off to check the pads, pull the sensors out (two 12mm each) and clean them off, and clean off the "bumpy rings" at the ends of the front axles.
                      If this doesn't work...I'm pulling out my stereo and pushing this car into a creek!!!!
                      OK not really...but I'll be pissed!!!
