CEl 12
    CEl 12
    sup guys just finished my h22 swap a couple of days ago, i'm getting the usual cels, but figured all them out except for the the egr, i have two sitting in my garage, both of them worked perfectly on the f22, so i put on the h22 go for a little drive and BAM, the cel 12, so i replace it with the other egr, clear the codes, go for a little drive and it comes on again, i'm like wtf , i put a gasket on there so i don't think thats the problem,
    i was leaning towards the solenoid i believe that goes in the black emmissions box on the firewall, the connection is clean, the egr is clean, dunno whats wrong,
    any help is apreciated
    ps. i do not want to get a chipped p28, and a egr block off plate, i have to get my car bar'd (sp) and i don't have the cash for it
    Members Ride
    bump
    Members Ride
      use an aluminum pop can and make a block off plate from that. works just like the normal plates. Justin will tell ya(doctor cipher)
        if ur in cali you will never pass smog.
        Retro!
        Hater
          i don't want to block it off yet, u just want to get the damn cel off,
          Members Ride
            Check for vacuum and make sure you're getting power at the connector on top of the EGR lifter deal. If your EGR lifter thing works and your gaskets are new, then either it's not getting power or it's not getting vacuum. I've got a code 12 too, it's my purge solenoid. It's getting vacuum into and through the EGR solenoid, and into but not out of the purge solenoid.
              i see, i will try that after work, thanks for your help
              Members Ride
                check each area fully, one by one. youve got a new valve, so check for vacuum, check a diagram and make sure each wire at the connector has a solid connection to where its supposed to be, check the solenoid in the black box...
                  When you did the swap did you swap any wires on the ECU? If you were looking at the 94-97 section of the swap info, it would tell you to swap 2 wires on the ECU. For the 90-93 you do NOT swap those wires. When I had my swap done, they swapped them and I had the EGR cel 12. Made them swap them back and no more cel! Just a thought. Oh, and I B.A.R.ed my swap, so it IS possible. Just make sure you have no cel's (I know, you're working on that) and you have all the required smog equipment for your chassis AND motor. I had to show the ref my ECU to make sure that it was a P13 and I had to open the "black box" on the firewall to show him the MAP sensor and all that crap. And if you have an intake and header, make sure you have all the CARB plates and/or stickers on them.
                  Good luck! And have fun with the swap!
                  Originally posted by Junior Smurff
                  Nevermind guys, google search works wonders!
                  I don't have road rage, my car just goes faster than yours!
                  Accords are for winners. And Grandmothers. But mostly winners.
                  I have grown so Tired of Internet Illiteracy. Please learn proper spelling and grammar. For your sake and that of your children.
                    the pins are not swapped, unless the previous owner did which i doubt cause i was and elderly man, i don't think he had a swap, anyways, i will still check and do the other stuff that was recommened, thanks for your help
                    i was driving yesterday seeing if the cel will come on, i didn't for a while, do i decided to hit vtak, i did and at 6200 rpm or soo i hear a loud scraping noise so i stop luck under my car and the back part of the resonator broke complety off, so i am no running resonator back exhaust, whack, i have to save up for a catback
                    Members Ride
                      im no h22 swap expert, but maybe you have to convert the egr plug? isnt there a difference between the two. on has three wires and one has two?
                      i probably am wrong, but maybe a possibility. if so please disreguard
                      nevermind..i found my answer..your only switching the connector from square to prelude round..sorry
                      good luck
                      x
                        well guys i check for voltage and vacuum according to haynes, the egr was the one that came out bad, i went to the junkyard and got one, put in with a new gasket, went for a litle drive and the code didn't come back
                        now i am having a little rough idle when am at the light, i will clean the iac, and the throttle body also,
                        also, i kind of have a stumble when i reach like 3000-3500 rpms, i will jerk until i shift, i was leaning towards the knock sensor on that one, not sure yet
                        Members Ride
                          knock sensor shouldn't do that. I'm running a P14 without a knock sensor, it's not doing anything wierd
                            Once the EGR valve is removed, I believe a new gasket is definately needed.
                            However, do you guys think that putting some RTV gasket material over the new gasket will ensure a better seal, or is that overkill and not needed?
                            1992 Accord Coupe 5-Speed
                              Least you fixed egr problem.
                              Good for ya!
                              1st car: Frost White 1991 Accord EX sedan.. (Dec. 1999 ~ Jan. 2001) *Sold*
                              2nd car: Black Pearl 1993 Accord 10th Anniversary sedan (Feb. 10, 2003 ~ Mar. 8, 2008) *Sold*
                              3rd car: Frost White 1992 Accord EX sedan (Jan. 15, 2008 ~ Aug. 12, 2008) *RIP*
                              4th car: Seattle Silver 1991 Accord EX coupe 5MT (Aug. 13, 2011 ~ Mar. 19, 2014) *Sold*
                              5th car: Black Pearl 1994 Accord LX coupe 5MT (Mar. 1, 2014 ~ )
