clutch or transmission?
    well heres a problem i was having before but it is getting worse i think.every now and then when i take off from 1st(manual trans) i will here this noise.i sounds like a train slowing down but not as loud.it sounds like when your brakes are going but a little different.its hard to explain but its def somethnig with the clutch.but itis only on take off any ideas?thanks.
    bump*
      Did you test if your clutch is slipping?
      Did one of your springs come loose?
      Did you recently change your tranny fluid?
      Does it only do it on cold mornings?
      When the noise starts, does depressing the clutch stop it or does it keep going? And if it keeps going, does it stop only when you come to a complete stop (no matter what gear (including neutral)or if clutch is engaged/disengaged)?
      TBILL
      92 Accord EX Coupe
      CB7, 5 spd, Seattle Silver
      91 Accord LX - no mods
      CB9, Auto, Cobolt Blue Cooking with Clinton
        i did just change my tranny fluid but iwas doind it before.it does it ONLY on take off from 1st gear.it will do it until i have the rpms up.and it only happens in 1st.i dont think my recent tranny fluid change has anythnig to do with it.
          put in first, rev it up, pop the clutch, and if tires spin/burnout, its prolly not your clutch.
          My song of the week (or till I change it): Snow Patrol - Take Back The City
            the exact same thing happened to me, as long as im understanding you correctly... it wasnt so much of a metal grinding like a train stopping, sounds more like brakes... idk. i ended up swapping an h22 and it fixed the problem... wish i could help you out... im gonna take a look at my old f22 clutch to see if it was in fact worn down too far. ill let u know.
              The reason I asked is because sometimes the wrong fluid can be put in and cause problems.
              Sometimes a spring can become loose and give a skreech. I think this could be a possibility.
              TBILL
              92 Accord EX Coupe
                i dont think honda manual tranny fluid is wrong fluid,thanks anyway.the noise sounds more like brakes but its def with the clutch.
                  No, that's happy juice for Honda
                  I still think a spring popped or your pressure plate is shot
                  Good luck.
                  TBILL
                  92 Accord EX Coupe
                    really,i didnt think that because would i feel it in shifting or something? i mean its only when i take off in first that it makes that noise,and it only happens sometimes.
