Well my car failed inspection because my foglights do not turn off with my highbeams going on. Whats the easiest way to fix this problem so they'll work for the inspection?
need simple help rewiring fogs
how are your fogs currently wired? knowing nothing about your set up heres what i would suggest:
using a relay run the 12v signal with high beams on to pin 85, cut the 12v wire leading to your fogs in half, connect the switch side to pin 30 and the side leading to the fogs to 87 and ground pin 86. this way when you hit the highs it should turn em offFA1
355
pull out the switch
