well both my battery terminalsare ***,there loose even when i tighten them down very tight,i have washers jamed in each terminal between the post and the termianls themselves,anyone got any tricks to fixing this,or should i get new terminals.thankx
battery terminal not tight
im guessing its the terminals coming from the car, not the ones sticking up from the battery... i really dont know how safe it is sticking washers in there, that seems too bootlegged to me. i say get a new pair of terminals, they arent expensive.
find a battery shop and buy some terminals from them. they will use this HUGE crimer to crimp it to the wire, i did that...my buddie owned the place..and gosh this terminal is better than stock..ALOT!! and it wont corrode cause of the material its made out of.
or do it yourself, but the crap at kregan isnt the best.What makes me laugh about forums, is that no matter how much you try to help someone, they dont take the advice. Go ahead and do it the hard way.
Retro!
Hater
Do you have those little anti-corrosion felt washers on your battery posts? If so, try taking them off and see if the cables can be tightened. If the terminals aren't completely seated all the way down on the post, they won't tighten properly.00 Jeep Grand Cherokee 4.7 V8 4X4
92 Honda Accord LX
95 Honda Civic CX
